Question about JVC KD-AVX1 Car DVD Player
Bypassing the parking brake feature
I need to know how to bypass the parking brake safety feature without spending more money. If you have one of these, you know I have spent enough of it already!
You can also bypass by connecting the black ground wire and purple bypass wire together , then connect them to the ground wire from the wiring harness.
Posted on Sep 28, 2007
Just earth the handbrake cable (light green) on a good earth point.
Posted on Jun 06, 2007
How do I find out which safety switch is bad on my 2010 New Holland workmaster 55 tractor?
Try setting the parking brake and make sure the mower is in the OFF position.
It should run without having someone sitting on the seat.
Jan 21, 2016 | Garden
Parking Brake Bypass.
i would suggest not ground the cable because as you know that a signal will travel the path of least resistance. you could interfer with your ecm and that is a whole different set of problems that will cost you a ton of money to fix. there is a reason for the safety features. I know it's a real pain, but the devices were designed this way so that the liabilty issues would never come back to bite them. I know this is not what you want to hear, but please rate the solution anyway.......thanks
Sep 19, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Wont shift out of park and red button dorsnt work
do the brake lights behind car work?
are you on flat ground?
you lost the operators guide, sure, car is old.
but it is there, it tells you what to do. (ive posted this 10 times here)
ALL cars with A/T tranny have a park lockout, device (safety)
on all older cars, they have a bypass.
to bypass the park lock safety device in an emergency.
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1182114&parttype=909
on many cars there is a bypass, method, (a secret part of console to bypass this, i dont have 95 opr, guide to look it up.
this jeep does have a cable from the ignition switch to this feature on the shifter, and they must both work, to get out of park.
is the red button loose, yes., then it has come detached. access it and put the rod back. (inside)
the tests and repair are in the fSM under transmission.
are you on lflat ground, are you parked on a hill.with wheels to the curb? park can stick 2 ways, the parking on hill+curb makes the parking pawl stick inside the transmission. (ask how to solve)
or the park lockout feature, is failing.
one is transmission caused, other is shifter lever parts failing.
every why possible for this to mess up is covered here.
lots.
http://www.jeepforum.com/forum/gtsearch.php?cx=partner-pub-7865546952023728%3A3954141121&cof=FORID%3A11&q=park+stuck&sa=Search
wild tricks> rumors
You can bypass it if you want to get out of park. Just turn the key past the lock position, but stop turning before any accessories turn on. This position will let you shift without the safety switch stopping you.
From here, shift into neutral and start the car. You can then shift into whatever gear you like.
Mar 14, 2014 | 1995 Jeep Grand Cherokee
How to bypass parking brake
  • The parking brake wire is a ground engaged when you have the parking brake on. So just ground the wire. Make it a very solid ground or it won't work. You basically changing the grounding location from the parking brake to a different ground. When you put it on a new ground it will be active anytime. Where as with the parking brake, the wire only gets a ground when the parking brake is engaged, follow?
  • As far as just bypassing it flat out as in not using the wire you can't, not for viewing the screen anyway. The ground wire is a safety feature and must be grounded somewhere to view the screen.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 24, 2011 | Pioneer AVIC-F700BT Car GPS Receiver
Kenwood DDX514, bypassing the parking break wire for video
Just hook up the parking brake safety switch from the unit to ground. That will do the trick. Hope this helps
May 23, 2009 | Kenwood DNX7100 Car Video Player
How do i bypass parking brake so i can watch movies
There is a parking brake switch lead that goes to the unit. You need to permanently ground it to bypass the safety feature.
Apr 28, 2009 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Mar 19, 2008 | Dual XDVD8265 Car Video Player
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Bypassing the parking brake safety
PUT THE GREEN WIRE TO THE GROUND IT ILL WORK I HAVE ONE
Apr 26, 2007 | Kenwood DDX-6019 Car DVD Player
JVC KD-AVX1 Car DVD Player Logo
972 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
