Question about LeadSinger LS-3000 Consumer Microphone
Missing parts from Leadsinger LS3700W
Tha back piece of our leadsinger system LS3700 broke while we putting in a song chip, my kid accidently stepped on it and as a result of that we later on ended up loosing the duet chip. I've tried buying the pieces thru leadsinger but haven't gotten an answer. If any one has a leadsinger that is broken and is interested in selling it for parts please contact me.
thanks gina
SOURCE: Leadsinger sub mic, modle LS
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
Good luck.
Posted on Dec 07, 2008
SOURCE: LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Posted on Dec 23, 2008
SOURCE: leadsinger microphone..... no sound on tv ..microphone seems dead
Did you go to Leadsinger.com and follow their instructions on doing a Hard Reset? It might help. I had the same problem but with a scrambled picture and no sound. The reset restored the picture but not the sound. Thats when Leadsinger returned it for a reconditioned one that worked worse than the first one. Now I get no response from them.
Posted on Apr 29, 2009
craigjamesbt
  • 65 Answers
SOURCE: Power lost on Main Microphone.
sound like you've been f#$^%d I suggest you boycott the company if enough people do it they will be forced to bankrupt then the government can bail them out and own the company this would give them the power to do things like fire the c.e.o.... still doesn't help your situation but it's fun to watch on tv
  • 7 Answers
SOURCE: No sound coming from wireless mic
check the battery, if dead replace new. check the switch might be a cold solder or loose wire and finally check the condenser mic by placing a multitester to the two connectors of the mic with one wire from the mic desoldered. if there's a continuity, then its good. if there's no continuity the mic condenser is busted. go to radioshack and find replacement mic condenser.
Posted on Jul 30, 2009
Ar all chips compatible with karoake systems
no
there are various issues , model of the system the make ( magic sing will fit magic sing ONLY )
if laungage font is different example hindi etc then also it will not work
chips made for very old models may not work on new systems
example ed series chips may not work on KV and KH series
for more please email me on mumbai11@gmail.com
Jan 07, 2015 | LeadSinger Audio Players & Recorders
Lyrics stick when playing songs on Leadsinger MVK2
Firstly all lines have to be timed. Then they will scroll. Other issue is the microphone is 16 Bit and we use mostly 32 and 64 bit file names as well as allowed characters within a page. 16 bit dos is limited characters specially comma or ( ) [ ] } : # $ so on will not work with this mic. Convert what doesn't work with FileEncConverter (available on web) and they will work. This program removes what mic can't handle.. Good luck
Jun 25, 2012 | LeadSinger MVK2 Consumer Microphone
Apr 29, 2009 | LeadSinger LS-3000 Consumer Microphone
Downloading
you could have downloaded a different format. try to read the manual of your karaoke, look what kind of format used, then download the same format.
Dec 26, 2008 | LeadSinger LS-3222 Consumer Microphone
Nov 10, 2008 | LeadSinger LS-3000 Consumer Microphone
LeadSinger LS-3000 Consumer Microphone Logo
128 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
Michial Gueffroy
Shehu Pro
Shehu Pro
johnny rebel
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
