Question about Car Audio & Video
I just changed battery and then i found i couldn't use radio anymore. The window show "code" everytime i tried to turn on radio. My car is 1995 Hyundai excel. How do you enter the radio code? Just punching in the 4 digits doesn't seem to work.
  • 22,306 Answers
Look in the handbook for the radio,it should tell you how to put the code in.most radios accept the code via the preset tuning buttons,ie first number is number one and so on then press number five to lock it in ,but some radios you press number one for first nunber then when its entered via tuner up and down press one again and enter second number.then am/fm button to lock but some use the tape player play knob ,really is confusing trust me on this .Change a customers battery and then find they dont have code number,also often happens is that change battery and dammed factory immobiliser cuts in...Who would be a mechanic?? any rich widows out their ??
Posted on Jan 01, 2009
Hi all....I've got a 2001 Fiat Punto, and after disconnecting the battery the radio is asking me for code. When I turn on the radio, it says
Most car radios need a code when theyve been disconnected , also some car radios are made to turn off after 20 mins use so that it cant be left on accidently , this is a battery saving idea , it can be bypassed though by rewiring a live connection to the radio rather than a connection through the ignition
Sep 23, 2012 | Car Audio & Video
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
About 3 weeks ago a friend had to disconnect the battery to change the head light bulb. After reconnecting the battery, I know longer had use of the radio. If I try to turn on the radio power it states...
the radio is an anti-theft type and needs a code to reset after losing power. The code is usually in the paper-work obtained when the car was purchased. the code is 5-6 digits long and is on a plastic card with the radio serial number.
the oil life message will continue to show until it is reset. With key off, hold the trip odometer reset button down. now, while still holding it down turn the key to on but don't start. Count to 20. The oil life message should be out and reset.
tires rubbing. could be a plastic trim piece in the fender well area has come loose from when the headlight bulb was replaced. Look under there and see if you can spot where the tire is rubbing. Turn the wheel one way all the way and check, then the other way and check.
Feb 11, 2011 | 2007 Honda Accord Sedan
Changed the battery on our chrysler grand voyager radio locked!
try to unhook the battery again for a minute or two..might help. then try the code again after hooking up battery again.
Mar 07, 2010 | 2004 Chrysler Voyager
Blaupunkt Car 300 Autostore - car radio
See hear :
http://car-radio-unlock.blogspot.com
car audio,audio car systems,car radio,unlock radio,radio code,code forradio,car radio codes,free radio code,codes for radio,radio unlock code
Nov 11, 2009 | Car Audio & Video
Rover 45 club diesel radio locked,battery change
The radio will have to be removed from the car dashboard
.Then please POST A NEW QUESTION
quoting  the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number (often found stamped in the metal casing )
Please note: Unfortunately not all radio codes are available by quoting the Serial Number
Sep 18, 2009 | Car Audio & Video
CHANGED BATTERY ON 2001 FORD EXPEDITION NOW RADIO DOES NOT WORK
It requires a code
You will need to quote the radio SERIAL NUMBER for the code to be calculated.
This is found on a label on the casing and will begin with M++++++ (or L or C or V etc)
Post the code request on a new post quoting this Serial Number
Sep 10, 2009 | Car Audio & Video
Okay. So my 1995 Volkswagen stereo is in safe mode and everytime i press the two buttons, it just blinks and won't let me enter the code anymore. How do I fix it?
With the radio in safe mode, you have to disconnect the battery again to reset the radio so you can enter the right radio code. If you don't have the radio code or it's wrong, keep me posted. be glad to help you get your radio working again. Good luck, friend.
Jul 22, 2009 | Volkswagen Jetta Cars & Trucks
2004 honda pilot radio code
I held down preset 1 and 6 while turning on the radio. The display then said "CODE." I punched in the 4-digit code (found on the side of the passenger side glove box) using the preset buttons, and viola! the stereo came back on.
Jun 21, 2009 | 2004 Honda Pilot
You need to re-insert radio code . If your radio is factory provided you may ask code from local hyundai dealer.
Give radio model number to search if can be found also on web.
Aug 06, 2008 | 1994 Hyundai Excel
Car Audio & Video Logo
221 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
