Question about Singer Inspiration 4206
Threading problem on Singer Sewing machine Inspiration 4206
While sewing it gets all tangled and knotted up underneath while the top stitch looks OK.
  • deemcfarland Jan 01, 2009
    I tried messing with the bobbin and then took it back to the store. They couldn't fix it either and sent it in for repair.
    Scholar:
  • 140 Answers
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
Posted on Dec 30, 2008
    Problem Solver:
  • 6 Answers
After some major fiddling that all the "birdnesting" underneath is actually the top thread. Make sure you thread it in the machine under tension and hear a click as your bringing it down and out of the "arm". I also had a problem with the bobbin popping out. I remedied that by unscrewing the black plate (with provided screw driver) and moved it to the left just a tiny bit. Now the bobbin is more secure and still seems to be working properly...for now...
Posted on Mar 21, 2010
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
My bobbin isn't sewing correctly
If the bobbin stitches look out of whack, your machine is probably threaded incorrectly. rethread with the presser foot up and see if this fixes the problem.
May 20, 2016 | Singer Inspiration 4206
Ruffler foot bobbin tangles
I suspect that the bobbin thread you are talking about is in fact the top thread that has been pulled under the material, make sure that the top thread is pulled into the tention discs firmly and that there is no fuzz in with the thread, also make sure the top thread is properly threaded and is actually in the take up bar .
Apr 08, 2014 | Singer Inspiration 4206
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
My sewing machine doesn't work properly.. after setting everything up it give the first stitch but then it doesn't stitch anymore... and I have what you call a bird-nest under my fabric.. don't know what...
I think that you are not threading it right, try this, totally rethread, now pull on the top thread with the presser foot up, it should pull smoothly, now put the presser foot down, pull top thread again, now it should barely move. This should seat your thread in the tension discs. I would also insert a new needle. (flat side facing the rear of the machine) If, you do not have your manual go to www.singerco.com and down load one for free, plus you can enlarge the diagrams for easy reading. It is not a bad idea to save a copy to you computer, in case you misplace the paper copy. Singer customer service is very helpful, at 1-800-4singer. Good luck, I hope that you can get some happy hours sewing.
Dec 06, 2010 | Jo Ann Inspiration 4206 Mechanical Sewing...
The straight stitch looks fine on top, but underneath it's all tangled and looks horrible. And the thread gets tangled beneath the bobbin and "E6" appears very often when I am sewing. It is very...
do you have the foot down? if not your getting whats called a birdsnest just put the foot down and then press on the peddal and then there should be no more knots ( by foot I mean the metal part that goes over your material and the needle goes through)
Feb 22, 2010 | Brother Sewing Machines
How do you thread a Singer?
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Jan 04, 2010 | Singer Inspiration 4206
Sewing machine
The top tension pulls the top thread up. The bobbin tension pulls the bottom thread down. A balanced tension is an an even knot between the stitches.
If the thread is messy on the bottom, the top tension is non-existent or is too low. The top thread tension dial should be on 4 or 5. Pull the thread out and re-thread the machine with the presser foot up. If it is still messy, perhaps there is a burr on the bobbin case snagging the thread.
Jun 19, 2009 | Singer Drop-In Bobbin 758B-28BH Mechanical...
5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Jan 28, 2009 | Singer 5050 Mechanical Sewing Machine
Selector dial stitches doesn't work
Suggest you ask the seller of yr machine. It runs on computers... They can malfunction. Singers were the Best for decades. From treadle days into the '70's. When a repair guy told me Singer only made parts for 2 yrs post purchase.
I have both of my Grandmother's treadle machines, and their scissors. Would Not buy a Singer, now.
Feb 05, 2018 | Singer Inspiration 4206
Singer Inspiration 4206 Logo
469 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
