Question about Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 760 suddenly stopped working - will not turn back on
Unit was working fine.  I put it to charge and when I disconnected it from the plug and tried to turn it on it just wouldn't. Unit seems dead
  • 1 more comment
  • tyrone_lesli Dec 30, 2008
    My phone will not turn on. Don't know how to get it repaired.
  • cmmonalisa Jan 02, 2009
    Thank you GS Dude!  I appreciate the input.
    Happy New Year!
  • grisel May 24, 2009
    Nuvi 760 was working great. Used the phone, disconnected and shut GPS off, now will not come back on.
  • 8 Answers
Try holding the power slide to the left and holding it there for 8 seconds. If that doesn't work, try charging it via your PC & USB cable. If that doesn't work, try a mains charger if you have one (I had to do this with mine). Good luck!
Posted on Jan 02, 2009
  • GS Dude Jan 02, 2009
    Leslie, try removing the battery from your phone, leave it out for at least 30 seconds, then replace and turn on. This "re-boots" your phone, it might work.
My nuvi 760 will not take a charge, turn on, or do anything when plug into my computer. I do need to register it it has never be.
  1. Make sure you are sliding the power button all the way to the left.
    • If the unit does not respond, it may be that the battery is not charged.
  2. Connect the nuvi to a power source such as the USB cable and your computer.
  3. Reset the device, if the problem persists, by sliding the power button to the left and holding it in that position for 10 seconds
    • This resets the unit and prompts it to power on.
Jun 09, 2010 | Garmin Nuvi 760 Car GPS Receiver
Speaker not working on Garmin 760
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 02, 2010 | Garmin Nuvi 760 Car GPS Receiver
My Garmin will not start up.
it sounds like your battery within the GPS Unit is died. You need to charge it somehow. Keep it connected to the car charger for around 30 mins and unit should turn on. Do not keep it on while it is being charged
Oct 18, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Unit got hot and stopped working properly
Nope! It may be the way you treat it
1) do not leave it in a hot car
2) do not plug it in and start the engine.
Goodbye SIIREF chip
3) do not just charge itb in the car Charge it from an AC or USB source first.
Please rate our help to keep the FREE service online ++++
Aug 30, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Our Garmin Nuvi was working until we stopped the car.
I've had this happen on three successive Nuvi 760's which I sent back, the serial numbers all suggested that they came from the same production batch..
Eventually I got a Nuvi 770 which has been fine. I understand that it's not a problem with the basic design as the 770 is really just a 760 with more memory, but it's probably a fault with a batch of components used during a production run.
This is not a DIY repair; contact Garmin even if your unit is out of warranty as they might offer a goodwill repair for free or at reduced cost.
Jul 03, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin Nuvi 760
I have the same unit. It comes with a trial subscription and then there is one time fee. The traffic will ONLY work when it is plugged into a power source in the car.
Remember to turn off the unit before you disconnect the cable. Otherwise the GPS unit will stay on and drain the power.
May 21, 2009 | Garmin Nuvi 760 Car GPS Receiver
Nuvi 760 garmin got wet accidentally
I dropped my 760 nuvi into the dog's water bowl... (by accident of course)...
It was working but would shut off and eventually would not start.
Using the correct screwdriver with the star head, I removed the two tiny screws at he bottom back of the unit. Gently from the bottom, pry off the back.
Be careful as the battery pack and the speaker wire are still connected.
Using a hairdryer on Medium heat and high fan, air out the unit until all water/condensation is gone.
Before putting back together.... check that the unit works, and charges by connecting thusb to a computer.....
Once content it is working, snap the cover back together and screw in the 2 screws.
Dec 17, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Will not turn on
Hold the off button (to the left) for 10 seconds... the system will restart and your garmin should work fine!
Sep 13, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin Nuvi 760 Handheld GPS Receiver Logo
1,878 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
