Question about GE Spacemaker JVM1640SJ Microwave Oven
Makes loud noise when running like a high pitched noise
The noise is real loud and can smell burnt electronics
    Scholar:
  • 140 Answers
You have a bad magnetron. Just replace the unit. It will cost more to fix than to buy a new one. There are great deals on new microwaves now.
Posted on Dec 30, 2008
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
I have Danby microwave, the food does not heat and there is smells like some thing is burnt. I have opened it and the high voltage transformer does not look burnt.
What is happening is that the magnetron is shorted, causing the high voltage transformer to overheat. That is what you are smelling is the insulation getting hot. When the magnetron shorts out, it makes a loud buzzing sound. Replacement magnetrons costs almost as much as a new oven so it rarely makes sense to fix.
Mar 09, 2011 | Danby DMW902 Microwave Oven
My built in lamona oven makes a smell like electicals burning and makes a loud whirring noise when switched on. Any ideas why? have had an electrician in to replace the mechanism inside and the problem is...
This sounds like the magnetron is failing, with a typical smell and a loud noise, there are two additional parts that can be a factor, the high voltage capacitor and diode. To pursue this you will need an appliance repairman or tv technician, the parts and labor will probably run the cost of a new microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have a 10yr old ge microwave--was heating up food when it started making a loud bzz noise and then burnt plastic smell came from outside of the microwave and it didn't heat up food. It was working fine...
Yes it is definitely the magnetron and yes you could change it your self if you are good with electronics and tools (considering that the MAGNETRON DRIVER CIRCUIT is OK) but it is normally cheaper to buy a new microwave oven
Sorry!
Jan 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noise followed by a burnt smell coming from the control panel. Not heating up at all.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.'';
May 19, 2010 | GE JVM1631 Microwave Oven
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Our Sharp microwave oven turns on, makes a loud humming noise, starts to smell like something is burning, but doesn't heat. Well, actually, we don't think it heats, we're too scared to let it run because...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} This can be caused by grease etc. inside the oven and on the wave guide which is the paper like thing in the oven. If you can remove it look for burnt areas which may can be scraped off or you may need to replace it. An appliance parts store usually has the material you can cut to fit you own.
Dec 10, 2009 | Sharp R-530ES Microwave Oven
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | Whirlpool GH8155XJ Microwave Oven
Oven runs but does not heat
This is going to be either the high-voltage transformer, the magnetron, or the high-voltage diode. Magnetrons are the mosty common failure in these, and there is a campaign underway to replace "underperforming" magnetrons. To see if yours is one of these, visit: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf
Apr 05, 2007 | GE JE1640WA/GA Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
410 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
