Question about Motorola Mobility HS810 Consumer Headset
Can't get my motorola verizon phone to work with blue tooth
How do I get my motorola verizon phone to workk with the blue tooth?
Are there commands to follow?
    Sniper:
  • 62 Answers
Go to menu. Click on setting. Scroll down to connections. Then click on sync. The pin is four zero's.
Posted on Jan 10, 2009
  • Jody Sinex
    Jody Sinex Jan 13, 2009
    Make sure the bluetooth unit is off first. Ten hold down the power button on the bluetooth until the LED stays on. Then click on sync in your phone. It will then prompt you to enter the pin it is four zero's
IHF1000 IS NOT PAIRING SUCCESSFULLY WITH MY VERIZON BLACKBERRY PHONE. I ENTER THE CODE 1-2-3-4 REQUESTED, NOTHING HAPPENS, SO THEN I REPEAT PAIRING STEPS?
yes most motorola blue tooth devices have a pin pairing code of 0000 andyou have to make sure your blue tooth device is in discovery mode.
Feb 25, 2011 | Motorola Radio Communications
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
Blue tooth voice commands
I had the same problem with a Motorola bluetooth. I had to return it to the store because it was defective. It wasn't a problem with the phone it was the bluetooth.
Jan 13, 2009 | LG VOYAGER VX10000 Cellular Phone
Cant get blue tooth to work
have you tried to update the software for this phone
Dec 31, 2008 | LG VERIZON VX3200 Cellular Phone
Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
Music and blue tooth
GET A DATA CABLE FROM YOUR CELL PHONE PROVIDER FOR A RAZOR V3 THIS WILL ALLOW YOU TO SYNC FILE DIRECTLYFROM YOUR COMPUER WITH OUT TAKING YOUR MEMORY CARD FROM YOUR PHONE
Jan 15, 2008 | Motorola Mobility RAZR V3
Blue Tooth Stereo Headphones and KRZR
From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support.
There is no solution
If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine.
I am going to the Verizon store to complain untill i get a different model.
In short the KRZR software is defective
Dec 26, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
I cant use blutooth to transfer files to other mobiles
My friend, Verizon is the worst company that makes bluetooth useless, The reason why this is? is because Verizon has its V cast music going, so they disable verizon phones to be able to transfer music or pictures phone to phone via blue tooth, this sucks i know, i dont think u can even put music using motorola phone tools as verizon phones has a totally different interface,
Dec 05, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Bluetooth headset
you need to turn on the headset and to order the phone to search for BT devices.
May 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility HS810 Consumer Headset Logo
63 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
