Question about XO Vision XOD1735 Car DVD Player
XOVISION CAR DVD PLAYER SOUND NO PICTURE
EVERYTHING WAS WORKING EXCEPT NO PICTURE FOR DVD TOLD TO HOOK BRAKE LINE WIRE TO EMERG BRAKE SWITCH AFTER THAT I GET SOND BUT NO SCREEN AT ALL EXCEPT VERTICAL LINES
  • certifiedrea Mar 20, 2009
    sound no picture switch hooked up pic comes in and out
Hook your brake line wire from stero to your ground wire. it needs to be grounded
Posted on Jan 17, 2009
My legacy indash DVD player screen won't come on everything else is working fine
CONNECT YOUR BRAKE SENSE WIRE UP TO THE EMERGENCY BRAKE SWITCH LOCATED ON THE PEDAL, THEN ENGAGE THE BRAKE WALA!! IT PLAYS!
May 26, 2011 | Legacy LDTSN7 Car Video Player
Sound works but there is no display on the monitor. it worked for the first few days then now cant see nothing. Does the park brake wire have to be hooked up in order to show the display cause i know it...
  • Yes it does. The emergency brake wire is a safety feature. If you don't have it hooked up it won't even display anything. If you do have it hooked up then you have to have the emergency brake engaged to be able to view DVD'S. The manufacturer does this so people can't just unhook the brake wire and watch DVD'S while driving
Regards, Tony
May 20, 2011 | Pyle PLD61MU Car Video Player
XO VIson DVD 7" works fine but when it is turned
sounds like you might have the wire that is always supposed to have power hooked to a switched power source
is it possible you hooked up power wires wrong
sounds like switched wire is hooked to battery and battery connection is hooked to switched source
only other option would be if ground is hooked incorrectly it should be hooked diretly to clean non painted metallic spot on cars body
if you need more help give me more details and i will try to help more
Good luck
Mar 13, 2011 | Panasonic XO-1515 XOVision Car DVD/CD/MP3...
What does pink/brake wire on dvd hook up to?! Ex: -LF- spkr or red power?! what?! I have a "Farenheit TID 580" car cd/dvd player. I have all the wires hooked up except the pink/brake. Is there a wire on my...
Hi all car dvd players have a emergency brake safety feature. The pink wire is to be spliced into your emergency brake wire, or there is a code you can purchase to bypass this feature.
Thank you for using fixya.com
Feb 09, 2010 | Eclipse (AVN7000) Car DVD Player
What would be the best way to bypass the E-Brake on a Jensen VM92
If you have the old firmware then all you need to do is ground the parking brake wire
OR
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jul 02, 2009 | Jensen VM9510 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
XOvision DVD/ Tv Tuner
the brake wire is connected to your hand brake to stop you watching tv while you r driving its a safty thing as you have not connected it it might be why you cannt watch tv hope this is of some help
Dec 27, 2007 | XO Vision GX1211 XOVision 12" Roof Mount...
XO Vision XOD1735 Car DVD Player Logo
586 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
