Question about Refrigerators
Ice maker not working-lever is in the right position
Why isnt the ice maker working when everything else is OK?
Lever was stuck-perhaps frozen
Posted on Dec 30, 2008
Turn off ice maker on Whirlpool refriferator freezer model ED2FHASB03
On the right side of the ice maker there is a long metal lever called a "bale". Carefully and slowly lift that lever to the 90 degree position. You should feel a catch and the bale will remain in that position. That shuts off the ice maker operation.
Oct 02, 2014 | Refrigerators
Ice maker isnt working after moving homes
Did you hook up the water line in the back? Check the lever on the icemaker to be in down position? Just starters.
Nov 22, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Everything seems to work just fine except the ice maker which stopped for no reason. I have checked everything. The water dispenser works well, the water pressure is more than sufficient. We lost power,...
I know of one trick that might solve your problem . First , make sure the lever that swings up and down during cycle is all the way down . Then , pour one eight ounce cup of water into the ice maker where the slots are . Hopefully , when the water freezes , the ice maker's sensor will detect the ice and start the dump cycle . If it does , and everything is OK inside the unit itself , it should be OK after it ejects the ice .
Oct 08, 2010 | Refrigerators
Ice maker isn't making the ice, but the water supply is working to make water? does not seem like the water is coming into the ice chamber it was frozen at the end of the spicet, so I took everything out...
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 31, 2010 | Kenmore 53542 / 53544 Side by Side...
Ice maker not working but water does work
Mar 29, 2010 | GE GSH25JFR Side by Side Refrigerator
Whirlpool stopped making ice, water side is fine.
Hi!
Please check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 27, 2009 | Whirlpool ED5SHAXM Side by Side...
Ice maker stopped making ice and everything is thawing in freezer"
Mar 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer stopped working
Mar 22, 2009 | Kenmore 57029 Side by Side Refrigerator
No ice
Hi!
Please check whether the ice maker has been turned off. Here's how to check.
Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please rate the solution.
Thanks
Rylee
Feb 10, 2009 | GE Monogram ZDI15C Automatic Icemaker
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
