Question about Panasonic CT-26WX15 26" TV
TV won't turn on
I got a blu ray player for Christmas and used it at my parents house, the resolution settings were to high for the TV so i manually set it back to factory defaults and hooked everything up. When i went to turn the TV on it turned on for a second and turned off. Now it won't turn on or do anything.
2 Suggested Answers
  • 11800 Answers
SOURCE: My Panasonic Viera 50" 1080i
The Panasonic doesn't detect the presence of the signal on the antenna input so it just skips it. shut down the player and turn the cable box on before attempting to switch sources.
But why aren't you using the Composite RCA connection on the cable box ? Not only you would get a much better image but the tv would detect that change in the AV source and should switch by itself. If it doesn't then the control processor is faulty and the entire mainboard will will have to be replaced
Posted on Nov 05, 2010
Blu ray shows the "Blu ray Disc" Logo on TV screen and then just show a black creen
Hi! and welcome to Fixya!
It looks like your tv is unable to handle the output video resolution from your bluray. The reason why you do not have picture on the tv screen after the bluray disc logo appears.
You can follow the instruction below to set the video resolution on your player to its lowest resolution:
1. Using your bluray remote control, press the following buttons in order... STOP button (press and release) ....HOME button (press and release)....POP UP/MENU button ( press and release )
Note: press the buttons in order with 1 second interval. Make sure tv and bluray are ON when you try this. If first attempt nothing happens, try this again.
2. When the home menu screen appears after doing the above instruction, you can set the video resolution again manually. Follow the instruction:
Using the BD remote control press HOME button > then go to SETUP > select screen settings > then change OUTPUT VIDEO RESOLUTION to Auto > change also 24P OUT to 1080P // set the BD-ROM 24P OUTPUT to Auto
The next time you turn on the bluray player you will have picture again.
Let me know if this works!
Oct 24, 2015 | Sony Televison & Video
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
I have a VL470M and am trying to connect a LGBD570 Blu-Ray through HDMI. It works fine through the composite input, but the HDMI says "no signal". Am I doing something wrong?
There are two possible issues. 1) The resolutions are mismatched. (output of the player and input of the TV) 2) the player can not confirm that the TV supports HDCP over the HDMI connection. Only 3 of the 4 HDMI ports are HDCP (high def copy protection) compatible.
Try a different HDMI port and make sure that you have the input set to the correct HDMI port. (There is an input button on the side of the TV as well as on the remote.)
The easiest things to check are turn off the Blu-Ray player and then turn it on again. Then press the Home button and navigate to the Setup Menu. Select Display and press the right arrow button, then select Resolution and press Enter. Then set the desired resolution and press Enter to confirm the selection. (Your TV should support 1080p from the Blu-ray player.) Then turn off the player since changing the resolution can lead to video issues.
I hope this helps.
(the manuals for the TV and the blu-ray player are available on line: http://www.vizio.com/vl470m.html and http://www.lg.com/us/tv-audio-video/video/LG-blu-ray-dvd-player-BD570.jsp Click on Support on either site.
Nov 13, 2010 | Televison & Video
My new Blu-Ray player will not send out an HDMI signal, except when I turn it on. It shows the Blu-Ray sign, then stops sending out any signal. is this a common problem?
This is not a common problem.
It sounds like you are receiving signal from the DVD player, but are having a resolution issue. After the splash screen is when the resolutions setting can affect your output. What this sounds like is the DVD player is set to 1080P and the TV is only capable of 720P or 1080i. If there is a resolution mis-match, connect a composite cable to the TV and set the resolution of the DVD player to AUTO, then check to see if you have an image from the HDMI connection.
If your TV is capable of 1080P and if this solution does not fix the problem, and all other outputs from the player perform the same, the unit is faulty and should be returned if still under warranty.
Hope this helps!
Jan 11, 2010 | Insignia NS-BRDVD Blu-Ray Player
35V432T wondering if it will support watching blu-ray
Hi
To answer your question;
There won`t be any problem connecting your blu-ray through components video cable or composite video.
But the tv won`t be able to deliver the high resolution(hd 1080P)that the blu-ray is capable of.
hope this help Merry Christmas
Dec 20, 2009 | Televison & Video
Hooking up ps3
To get 1080i (the 50V will not do 1080P) from the Blu ray player you do have to use HDMI output on the PS3 to the DVI input.
I found one at Walmart. Phillips makes an HDMI to DVI plug also at Wmart.
The PS3 must be set for the output you want on your TV.
Look in your manual in the PS3 box or go to http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
The web site has much more detailed instructions, but the basic answer to your question is below.
  • The cable required to output a particular video mode may not be included with the product and additional purchases may be necessary. For details, refer to the documentation supplied with your system.
  • If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
  • Copyright-protected Blu-ray video discs can only output at 1080p using an HDMI cable connected to a device that is compatible with the HDCP standard.
  • Hope that helps!
    Merry Christmas and Happy Holidays to you and your family.
    Dec 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
    No Display
    If your resolution on your TV isn't capable of 1080p it will not show anything on screen. You should set the Blu-ray player to max resolution of your tv.
    Hope this helps.
    May 27, 2009 | Sony BDP-S300 Blu-Ray Disc Player
    Does blu ray technology work with old TVs
    Yes, provided the TV can accept one of the Blu-Ray player output connection types. But there is NO advantage over DVD, the reason is that Blu-Ray is designed for 1080i and 1080p resolution high definition TV's, and you won't get better resolution simply connecting a Blu-Ray player to an old TV.
    Feb 27, 2009 | DG Locks & Locksmithing
    Ws-65807 65" mitsubishi rear projection tv
    For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
    Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
    Panasonic CT-26WX15 26" TV Logo
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
