I have a Samsung flat screen monitor and it has went out again on me, this is the second one I have had by Samsung, my other monitor was replaced, and now this one has went out also. The screen is black and the power light keeps blinknig off and on and it want shut down or come on or light up. To turn it off it has to be unpluged. Can You HELP!!!
I would try to look at it really close to see if the backlight is just not working, and if its realitivly new i would send it back to samsung
Posted on Dec 30, 2008
Screen went black! Briefly comes on, very faded, then blacks out again. Haven't had for more than a year...
I've had a similar issue with my Samsung screen awhile back. It should be that your monitor's power supply unit has degraded and needs replacement. You will have to send it to Samsung for repairs.
Mar 04, 2011 | Samsung 933SN Monitor
The monitor is a samsung syncmaster 920MW. It works when I turn it on, but then after three seconds it cuts off. The power indicator LED is still green. However the display is blank (as if the monitor were...
this is usually a short that reacts to heat. as it runs and warms up it shorts, then it cools, etc, etc. I would just replace the monitor. With the black friday deals you should be able to get a flat screen for under a hundred dollars.
best of luck
Nov 24, 2010 | Samsung Computers & Internet
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
Monitor screen is black
bad capacitors on the power board internal to the monitor they need to be replaced.
Mar 02, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
SAMSUNG SYNCMASTER 191T PLUS
I have the same problem. Have you found a solution?
Aug 24, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
