Question about Air Tools & Compressors
IR 2135TI repair manual
I have a IR 2135TI impact wrench, and need the disassembly and assembly instructions. I found them on the web last week, and didn't save the page, and now I cannot find them. Any ideas where to look?
  • lnofdernie Jan 17, 2009
    Thanks Idaho_Biker, I already had the schmatics of it, but what I was looking for was the step by step directions on reassembly. I talked to a person at IR and he told me he would email them to me, but he never did, so I took the schmatics, and put it together with that. The gun runs great now. Thank for your time.
  • 32 Answers
Go to: http://www.irtools.com/contact/?pro=&cat=&sbu=&formType=ussales
make a Request for schematic, they have always given me great assistance.
Posted on Jan 17, 2009
Replace reverse valve ir 2135
Did you ever get the 2135 reversal valve installed?
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
YOU NEED TO COMPLETELY DISASSEMBLE THE WHOLE TOOL.
START BY REMOVING THE 4 MOTOR HOUSING SCREWS, SLIDE THE HAMMER CASE, HAMMER ASSEMBLY AND MOTOR ASSEMBLY FROM THE MOTOR HOUSING.
THE REVERSE VALVE WILL BE VISIBLE NOTE THE ORIENTATION ON THE AIR OPENING IT LOOKS LIKE A HALF MOON, THE VALVE WITH EITHER BUTTON PRESSED IN SHOULD AT A 45 DEGREE ANGLE.
NEXT YOU WILL NEED TO REMOVE THE INLET BUSHING ASSEMBLY THAT IS HELD IN BY A CLIP THE IS VISIBLE THROUGH 2 SLOTS LOCATED ON THE LOWER SIDES OF THE GRIP, THEY NEED TO BE PRESSED IN TO SLIDE THE INLET BUSHING OUT THE BOTTOM OF THE TOOL. THERE IS A SPECIAL TOOL THAT SIMULTANEOUSLY PRESSES BOTH SIDES OF THE CLIP BUT CAN BE SUBSTITUTED WITH 2 SMALL FLAT HEAD SCREWDRIVERS.
ONCE THE INLET IS REMOVED, THE TRIGGER CAN SLIDE OUT THE FRONT OF THE TOOL
NEXT USE A SMALL FLAT HEAD SCREW DRIVER TO PRY THE REVERSE BUTTON OUT OF THE HOUSING, INSERT THE SCREW DRIVER INSIDE THE INNER EDGE TO PRY OUT,
ROTATE THE VALVE 45 DEGREES IN THE OTHER DIRECTION TO REMOVE THE SECOND BUTTON.
NEXT PUSH DOWN ON THE REVERSE VALVE IT WILL COME OUT THE BOTTOM.
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/IR%20Industrial%20Tools/Impact%20Tools/04584033_ed2.pdf
How do i install trigger kit in qtimax
Unfortunately IR does not have a maintenance manual for this model, but you can use the manual for a model 2131.
The air inlet assembly is slightly different on both models but the parts kit will fit both models, assembly and disassembly are the same.
Follow this link for a maintenance manual:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/45481785_ed1.pdf
Apr 03, 2013 | Ingersoll Rand Ingersollrand 2135timax 12"...
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
Ingersoll Rand 2100G air impact wrench turns when air is hooked up. I can stop it by hand and then use it with the trigger, and it works fine, but it continues to run even when I let the trigger go. What...
The I.R. 2100G shares parts with the 2135 series impact, the throttle valve seal on these models have a tendency to wear out or deteriorate casing the throttle valve to by pass air. On the model 2100G the parts in question is only sold as an assembly (item# 22).
But you can disassemble the inlet bushing and install an inlet parts kit p/n 2135-K303, it includes all the necessary parts.
I will provide to links for you to look at
2100G: http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45667599_ed2.pdf
2135Ti : http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
The I.R. parts list shows the inlet bushing in detail.
Oct 28, 2011 | Ingersoll Rand Air Tools & Compressors
I have no problems in reverse but gun seems to stop when trying to tighten. Had the same problem with my 1st 2135ti
Sounds as though you have broken or worn hammers. Try KCTool 715 445 7700. They can and will help you.
Oct 26, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
Have an IR 2135ti can't get reverse valve part #24 out of handle
you need special tools to disassemble the air inlet - and i have it
Jan 25, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
Need repair diagram ir 2135ti want to reassemble trigger for 1/2" 2135ti
try going to irtechpubs.com nd under industrial tools you will find your model number and can download a breakdown for it. Let me know if you have trouble, I went thru about 15 sites before I found it.
Nov 02, 2009 | Ingersoll Rand 2135Ti Air Impact Wrench
Air Tools & Compressors Logo
2,875 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
