Question about Frigidaire GLDB958JS Dishwasher
Dishwasher problems The dishwaher dose not wash like it used to. the arms inside dose not spin or spray water in the wash cycle. the moter pumps the water out and the heat element heats the water up like it has before.
  • robert williams May 04, 2007
    a vary promt response. Thanks
  • Fridig_air Sep 08, 2008
    I have the same dishwasher and have the SAME EXACT problem!!! The dishwasher is not washing... sprayer not spinning? I don't think that anything is clogged. I think it it may be a pump motor issue? Can anyone offer help? Thanks!
    Novelist:
  • 114 Answers
TURN POWER TO OFF ... REMOVE THE LOWER RACK. THE SPINNING SPRAY BAR USUALLY WILL LIFT SRAIGHT-UP AND OUT ... INSPECT TO SEE IF ANY THING IS IN THERE TO PREVENT IT FROM SPINING FREELY ... THEY SPIN BY WATER PRESSURE SO THE NEXT THING TO CHECK IS THE WATER SUPPLY VALVE (MOST OF THE TIME IT IS RIGHT UNDER YOUR SINK.) AND THE STARAINER is LOCATED WHERE IT CONECTS TO THE DISH WASHER. MAKE SURE YOU HAVE A BUCKET AND RAGS HANDY FOR SPILLS... CAREFULLY TURN THE VALVE OFF AND REMOVE THE COMPRESSION FITTING NUT THAT IS ON THE "SIDE CLOSEST TO THE WASHER".... THEN CRACK THE VALVE OPEN AND FILL THE BUCKET UP A FEW TIMES TO ENSURE GOOD WATER FLOW. TURN VALVE "OFF" AND GO TO WERE THE LINE OR HOSE CONNECTS TO THE WASHER. REMOVE THE CONNECTION ... INSIDE YOU SHOULD FIND A STRAINER THAT MAYBE CLOGGED UP. CLEAN-IT AND MAKE SURE TO TIGHTEN ALL THE CONNECTIONS BEFORE STARTING A TRIAL RUN. NOTE: THERE IS A SOLENOID INSIDE THE MACHINE THAT CAN STICK AND GET CLOGGED BUT USUALLY ITS THE VALVE OR THE STRAINER. GOOD LUCK AND STAY DRY ... Joe_Rex
Posted on May 01, 2007
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
Dirty dishes
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher.
The motor (and pump) located beneath the dishwasher.
Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem.
First of all: filter plate clean? Clean any locked hole.
1) Can you remove the upper spray-arm and verify if holes inside are locked by any residus. Clean the holes , and check if pure water come out when you fill the center hole with some water.
2) Switch on the dishwasher , coldest wash cycle dish-washer empty and without the upper spraying arm. Once you hear water streaming in, open the door and look if a little water fountain comes out from the center hole where the upper spraying arm was fixed. If not, this canalisation is blocked and should be cleaned. Try to continue the wash cycle, often the water pressure will clean itself this canal. Check also lower spray arm: it should be rotating a while and ejecting water thru its holes. If not, verify this canalisation as well.
3) Put the spraying arm again on its place, verify also the sealing else water pressure is going down and spraying will not turn and spray water.
4) Again, continu a wash cycle, open the door and look; upper arm should be rotating and some rays trown out.
Hopefully, this helps .
If not, pump pressure may be low; have a repair verify, can be that only brushes in the motor must be replaced, can be the pump worn out and to be replaced at all.
Aug 12, 2008 | Asko D1776 Built-in Dishwasher
Dish washer not washing dishes water coming in but the arms are not spinning am thinking the pump may be gone the model is omega dw501wa
Hello; this dishwasher has a pretty poor track record, but since you have it, I'd suggest the obvious solutions first. You only mention that the spray arms aren't spinning. If this is the ONLY problem, and the dishwasher empties properly, the problem has to lie in the spray arms, since the same pump that runs the sprays pumps the water out of the dishwasher.
If you have the manual for the machine, remove the sprays and check that they are clear of all debris (small pieces of bone, plastic, glass, food) that are usually removed when you rinse the dishes prior to putting them in the dishwasher. These small particles are blown into the spray holes when the sprays try to run, and block the holes. Often, they drop back into the spray arms when the pump is off, so they aren't visible on inspection. For this reason, smack the spray arm into the palm of your hand sharply, then shake the arm. If you hear rattling around inside the arm, it's debris. It's a little time consuming, but you need to get it out, and check for this problem regularly.
While the arms are off the fittings, close the dishwasher and start the cycle. Once it reaches the point where the sprays come on, if the pump IS working, and the debris screen on the food chopper is clear, you should hear the water gushing inside.
If you DON'T hear the water gushing, the next thing to check is the food chopper debris screen.
If all else fails, and the washer does NOT empty at the end of the cycles, you probably have a pump problem.
If that's the case, considering the history of these machines and the cost and labor involved in installing a new pump, you should consider getting a new, more reliable machine. Check Consumer Reports next time. (;<)....Good Luck!
Jun 16, 2012 | Dishwashers
Dishwaher does not spray water during the wash or rinse cycle
Check m/c water pump. Look for clogged water ways inside the machine wash chamber. Check you water inflow to the machine also.
Apr 06, 2010 | Maytag 24 in. MDB5600A Jetclean II...
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
Dishwasher pump will drain but not force water into spray arms
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Dec 11, 2007 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Dishwasher Repair
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 10, 2007 | Dishwashers
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Frigidaire GLDB958JS Dishwasher Logo
166 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
