Question about Western Digital External USB 2.0 80 GB Hard Drive
I am trying to access my hard drive, and it is not working. I have plugged it in, and the blue light comes on, blinks, and shuts off. What is wrong? Does it have to charge?
  • 63 Answers
No it draws power through the USB port. Try it on another computer, if it doesnt show there either, then you may have a bad device.
Posted on Dec 30, 2008
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
Western digital 2tb my passport keeps blinking; not detected
It is possible that the computer was still accessing the drive when you unplugged it. Depending on what it was doing this could have corrupted files on the HDD.
Does your "device manager" see the drive at all... either as a drive or USB device?
Nov 03, 2013 | Western Digital Computers & Internet
Light on front just blinks
this could be for several reasons. Normally a light blinking on a hard drive is to say that the disk is being accessed. but if it happnes for a long period of time, then you might have a issue with the disk itself.
i suggest that you try the device on another PC, a friends or relatives. if you have the same problem , i am afraid that you might have a disk error
May 06, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Red and blue light alternately blinking. What can i do.
Remove the drive from the enclosure and either install it in your machine as a slave or you will need to buy a new enclosure and put the drive in it.
Sep 17, 2009 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
My picture is green the it shuts off with light blinking in front
that's very hard to fix, you need to monitor every test voltage pin if is in normal. try also replace crystal capacitor thats one monitor with the jungle IC.
Apr 30, 2009 | Sony KP-57WV600 57" Rear Projection...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Can't restart, can't connect
Please check the smps this type of problams are coming whaen smps is not working corrctley than cheack with ram slots also please verfiy the whare the problam is check one be one
Jul 21, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Simple tech 500 gb external hard drive
It is not necessarily the hard drive itself that has failed. More likely it is the enclosure and the hardware within in that enables you to access the device. The only way to know for sure, is to connect the hard drive inside your PC and see if you can access it. If it accesses fine when inside your PC, you should be able to buy a new enclosure for your drive and be back up and running with very little effort. If the drive cannot be accessed when hooked up inside your PC, it is unfortunately dead.
Good luck
Jun 28, 2008 | SimpleTech Computers & Internet
Light doesn't turn blue at all
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Mar 31, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Communication between hard drives
Flashing light on enclosures  usually means the drive is being read, written to, or mounting.
Oct 27, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Western Digital External USB 2.0 80 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
