Question about Kenmore 24902 Top Load Washer
Washer won't change cycles
Washer fills, and completes wash cycle but when it trys to shift into spin the motor runs but the transmission does not fully ingage the gears, if I open the lid for a second or so and close it it will engage and spin as it should. This happens through the intire cycle. Thanks for your help. dhu1988
    Novelist:
  • 114 Answers
The loading door does have a saftey switch for the spin cycle ... they can go bad or can switch intermitently when washer shakes. If the switch is not the problem ...The clutch assembliy is out of adjustment ... possibly worn mechanism internally. There is a solenoid that holds the clutch assembly in gear. That maybe intermitant. Unfortunately most all manufactures make specialty tools that are made only for there washers. I personally have a half-dozen wrenches that I have to fit most of them. I would suggest calling a "Liscensed Factory Certified" Appliance Repair Company that works on your particular brand and model. Honest Companies offer a "flat-rate" diagnostic fee. If they determines the Clutch assembly has to be replaced ... consider the COST before having it repaired.
Posted on May 01, 2007
Kenmore 70 series washer model 82871420 only runs on rinse cycle
Is the timer going through the wash time? Is the motor running but nothing happening? If the motor is running, then either it has not shifted into wash or the transmission is broken. An electrical coil shifts the transmission, it could be bad, or the trans it self is shot, time for a new washer.
Nov 04, 2012 | Kenmore Washing Machines
Washer fills but will not agitate
When you say the rest of the cycles. make sure it is spinning. That washer will fill up and drain and not agitate or spin if you have broken the couplier between the motor and transmission the motor reverses. tip the machine back and feel right behind the motor for a plastic coupler. In wash check the bottom part of the agitator if its moving and the top is not you will have to replace the doggets in the agittator.
Apr 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
Will not go through the wash cycle
sounds like it is the transmission in bottom of washer is cheaper to replace washer than have a service man repair
Jul 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Kenmore 24902 Top Load Washer Logo
126 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
