Question about HP A4033A 20 in. CRT Monitor
HP A4033A monitor: Power saver (warm up) period problem
During warm up (or power saver time) screen encrease vertical size from ~70% to full about 5..7 min. It wasn't before and become with monitor
age. Also, need several attemts to properly turn on power bottom unless it lights green (other way it lights yellow with some couple indicators). After this transition period monitor working very good for long period of time.
I belive this simptoms of malfunction have to be fixable.
Please help me or send manual w/scematics.
Michael
  • misha_s Dec 31, 2008
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    I've reed on link you directed and it seems to
    be not a specific solution of my problem, but mess of different E-mails related
    to some kind of monitors understandable for electronic specialist.
    But I'm standard PC user, so your answer is puzzle for me even I have
    engineering background.
    So, I'm not accepting this service (and matter of deal is not money amount, but
    your bad answer).
    Sorry, but I expect simple professional suggestion because according forum
    my monitor problem is common.
    Regards,
    Michael
    Genius:
  • 1,550 Answers
You need to replace the crt . CRT is not working properly . It is due to aging the components life fails and you get this kind of symptoms . There is no fix other than replacing it .
Posted on Dec 30, 2008
    Novelist:
  • 163 Answers
K..
read service manual from the link ---
http://www.cs.utk.edu/~shuford/terminal/screen_news.txt
Thanks
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Why no video
a HP monitor. as old as 2006... (o0ps)
read the manual yet? on "power saver modes" turn off them?
i bet you dont know spec, on caps. it's not published by HP ever.
most are +80% - 20% for filters. (ever seen that?)
so a 100uf can read 180uF, or 80uf and is IN SPEC.
but no caps stated, by you, lots there are...
my guess you are
looking for the caps used in china long ago that all failed, every one.
first off you never fully stated whats wrong, in DETAILS.
first have good running pc , with live VGA output (using VGA are you)>? unstated...
the MON, will now live sync, now , Horz and vert, on both pins
the OSD screen now works, if not the monitor is bad.?
or see No/syn, no sig, out of range or no input errors.
Monitor Going to Sleep
see page 34? in your manual yet?
and page 31, turn of power saver ?
if OSD is dead, say so first.
OSD can be locked. push mon menu button for 10sec, now unlocked
then go to OSD screen
http://h10032.www1.hp.com/ctg/Manual/c00834092
Power-Saver Feature
When the monitor is in normal operating mode, the Power li
ght is aqua-white or green (depending on model) and the
monitor uses the normal watts of power. For power us
age, refer to "Technical Specifications" (Appendix B).
The monitor also supports a power-saver mode that is
controlled by the computer. When the monitor is in the
reduced-power state, the monitor screen is
blank, the backlight is off, and the
Power light is amber. The monitor uses
minimum power. When the monitor is "awakened," a brief
warm-up period occurs before the monitor returns to
normal operating mode. The energy-saving reduced power stat
e activates if the monitor does not detect either the
horizontal sync signal or the vertical sync signal. The powe
r-saver feature must be activated on your computer for this
feature to work, << read that carefully?
turn this off ? first?
osd-vboix4tqi2kfzapulla5cn4x-5-0.jpg the early models of the monitor
had CCFL back lamps, and the 2 inverters are on the main power board. left side here
http://i.ebayimg.com/images/g/2-wAAOSwzSRZxoWH/s-l1600.jpg
Sep 28, 2017 | HP Compaq WF1907 19" LCD Monitor
When im on the computer the monitor shuts off a box appears saying power saving enabling monitor to shut down in a few seconds and then it restarts
Windows provides the following plans to help you manage your computer's power:
  • Balanced. Offers full performance when you need it and saves power during periods of inactivity. This is the best power plan for most people.
  • Power saver. Saves power by reducing system performance and screen brightness. This plan can help laptop users get the most from a single battery charge.
  • High performance. Maximizes screen brightness and might increase the computer's performance in some circumstances. This plan uses a lot more energy and will reduce the amount of time that a laptop battery lasts between charges.
    Note
    • High performance doesn't appear on the battery meter by default. To turn on High performance, open Power Options by clicking the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, and then clicking Control Panel. In the search box, type power options, and then click Power Options. Under Select a power plan, click Show additional plans, and then click High performance.
If these plans don't suit your needs, you can create your own power plan, using one of these plans as a starting point.
Feb 13, 2011 | Gateway 510 S PC Desktop
We have just bought an LG 23 inch monitor. Everything okay on it except for the proper resolution. The monitor no. is W2343T. I have put the resolution of 1920 x 1080 and frequency of 60 hertz on it as...
I think the problem is going to be in the Windows software, and not the settings on the monitor. Not sure which type of computer or which Windows you're running, but get into control panel, monitor settings and see what you can do. Windows help and support might be able to assist you.
Here's an excerpt from ncix.com:
Cons Clumsy front panel controls
Vertically, picture is no larger than my old 17"
May require video card upgrade for higher resolutions
Front panel illuminated power button is distracting
Summary Overall, I really like this monitor. But don't expect a size increase vertically over a 17" display. I actually lost half an inch. I prefer a 16:10 aspect ratio so I'm not actually using the full wide available. If you're like me you can save some change and go for the 2243.
Not sure if that will help, but there it is.
Here is the whole blog:
http://ncix.com/products/index.php?mode=productreviewread&product_id=37490
Not sure if this will help, but you might check it out:
http://www.sevenforums.com/graphic-cards/19981-cannot-display-1920-x-1080-a-2.html
Good luck, and hope this helps.
Sep 20, 2010 | LG Computers & Internet
Automatic shut off?
Usually you set this by going into the power saving settings in the screen saver settings.
You can set the monitor to shut down pretty much when you want it to from this settings screen.
Good Luck,
-a.
Jun 07, 2010 | HP 2009M Monitor
Full screen probs with netflix
This has nothing to do with Netflix, you would get the same result with any DVD regardless of its origin. Chances are that is the laptop trying to revert to a screen saver or power save mode during the movie.
Check your laptop's power and screen saver settings. If you are experiencing the problem every 3 minutes or so, your screen saver is most likely scheduled to go on after 3 minutes of inactivity. The same goes for your monitor-- it may try to dim or turn off after a certain amount of time.
To change these settings to a longer delay, go to your desktop and right click. Select "Properties". Choose the "screen saver" tab, and change the "wait:" field to a higher number. Or, just turn the screen saver off by selecting "(none)" under the screen saver dropbox. You may also click "Power" and change the time for "turn off monitor" to "never", or a longer amount of time.
Jan 04, 2009 | Toshiba Satellite M115-S3094 Notebook
How to turn off the cleaning page feature in Xerox Phaser 8500
Actually what is happening is your machine is going into the power save mode and staying there for a long time.
What happens then is you get a full warmup. When the machine warms up, it will turn on the compressor and drain the resivour because Xerox wants a "fresh": supply of ink in the print head.
Its excruciatingly expensive and wasteful.
Here is something that can help. I am not sure you can completely disable the energy save mode. Thanks Al Gore...
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen
Dec 17, 2008 | Xerox Phaser 8500/DN Printer
Monitor losing power
It has possibly decided to close down. Some monitors have a power shutdown as power saver of two or more levels. It may wake up from pushing a button on the monitor. Check on the screen settings to see if monitor can stopped doing this. I had a monitor that did this years ago, long since replaced.
Sep 08, 2017 | Westinghouse LCM-19v1 Monitor
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
Monitor displays vertically
If you mean that your screen display became narrower, then there are usually buttons on the screen to fix this, among other adjustments of the screen. the setting you're looking for has a two way arrow going horizontally through the middle of an icon representing the screen. In case i'm misunderstanding your problem, or this does not help, you can also try to let the screen rest for a while(at least 30 minutes), and turn it back on, to allow it to degauss. Good luck
Mar 13, 2006 | HP A4033A 20 in. CRT Monitor
HP A4033A 20 in. CRT Monitor Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
