Question about Jada Remote Control Speed Racer Mach 5 Car RC 1:10
Car stopped going in reverse
Jada toys Speed Racer 1:10 remote control car, opened Christmas day, purchased 10/3/08. Car worked beautifully for about an hour, and then would no longer go in reverse. Car still works well going forward, and turning left & right.
2 Suggested Answers
  • 18 Answers
SOURCE: I have a jada toys radio controlled chevy concept.
You can send it to be fixed or you can trade it in for a new one. Just look for the phone number online
Posted on Aug 04, 2010
My 2010 camaro ss from jada toys incorporated's steering doesnt work i need your help
It could be that the servos on your car could be shot. How old is the car?
Apr 03, 2013 | Toys
I bought a new 9.6V NiCd pack battery but after I charged it the car run only 1 min or less. I measured the pack and it shows only 4V. I'd appreciate your comments.
  • A 9.6 volt battery should read around 10 volts or higher after a full charge. If your battery only worked for a minute and has 4 volts then you received a bad battery and it should be returned for a properly functioning battery. Or your battery charger is not charging properly.
  • It's simple enough to test. Get a volt meter and set it to DCV (DC Volts). Now turn the charger on as if you were going to charge the battery. Now place the positive terminal in the positive side of the connector on the charger. Do the same with the negative side. If it does not read AT LEAST 9.6 Volts (probably more like 10.2 - 10.5 Volts) then the charger is not putting out enough to charge the battery. A new battery charger will be needed.
  • If the volt meter reads anything lower than 9.6 then the battery is bad and you will want to get it exchanged.
  • Hope this helps and thank you for using FixYa.
regards, Tony
Jul 25, 2011 | Jada Remote Control Speed Racer Mach 5 Car...
I need a replacement 27MHz remote control for a Playskool Tonka Bounce Back Racer model #09995. This model has been discontinued. Would another 27MHz remote, with forward & reverse control features...
Yes! The FastLane brand works. I thought my bounce back was a loss because the remote doesn't work until my older daughter played with her remote control car in the same room. The Tonka Bounce Back responded very well to the FastLane remote. And fortunately, FastLane is pretty inexpensive. Good Luck!
Jul 10, 2011 | Playskool Tonka Bounce Back Racer Remote...
My rc car stopped working after 3 mins of play time. i put new batteries in and still not working. my son got it for christmas. there is a paper that says if u have problems go to support@toys 1628.com but...
My son receive a Christmas present a remote control car and it doesn\'t turn....... I emailed the support@toys1628.com 12 days ago and they have not responded...... this is a crappy way to do business
Dec 24, 2010 | Parents My First Rc Car
Car acclerates itself to full speed
ok friend first change the batterries of the controler wirh a new ones if the problem persit yoyu may need to open the controler and pull the pins where the controler of speed go nicely, some times with the use the contacts get to near the contac from the board of the controles this might thew the solution i hope it works!!!
Dec 13, 2009 | Nikko Toys
Put batteries in and car won't move
batries are needed in the cantrol bolth have to be on and then sinced most remot controles have a button by the batires for that
Aug 06, 2009 | Jada Remote Control Speed Racer Mach 5 Car...
Broke remote
any remote with the same frequency as your original will work
Jun 05, 2009 | Jada Remote Control Speed Racer Mach 5 Car...
Jada Remote Control Speed Racer Mach 5 Car RC 1:10 Logo
116 people viewed this question
Top Jada Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Jada Toy Expert? Answer questions, earn points and help others
