Question about Samsung CLP-500 Laser Printer
"Lever Unlocking Error" Message
Keep getting "Lever Unlocking Error" and "install Transfer Belt" error messages alternating on the display.
I've turned CLP-500 off and on again, and I've unlocked and relocked lever, but nothing has worked.
How do I resolve the error message?
Thanks ... Tom
    Problem Solver:
  • 8 Answers
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
Posted on May 06, 2009
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Transfer belt error problem
*Check patch sensor *Alternatively your IBT belt needs to be replaced
Aug 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Error Code on Samsung CLP 500N
I don't enjoy these lovely cryptic messsages from Samsung either. Have you searched the Samsung support site? I have found some answers there that weren't in the manual.
Oct 26, 2008 | Samsung CLP-500N Laser Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
Phaser 6100 - lever unlocking error
This printer is same as Samsung CLP-500. So the problem is the same: Contaminated transfer belt sensor.
Do as follow:
Lift transfer belt assy from printer(Drop down back door 90 degree, press white button, lift top cover and release 2 locking levers, grab handle, pull the belt unit out), turn upside down & rotate plastic roller until small clear "window" appears along one edge of belt. Clean both sides of clear window with cotton bud. on same side as window, remove 2 screws securing flimsy plastic cover to gain acess to sensor, (follow red/black wires)remove a screw and pull out "U" shaped sensor(light transmiter and receiver), cotton bud and blow away dust on slits on inner surfaces of sensor. Reassamble and everything should be ok.If not, senser may be too contaminated, clean slits vigorousley with cotton bud, or maybe you just need a new sensor.
The theory is that printer detect transfer belt by transmit light through the clear "window". If either window not clear or sensor is contaminated, light will not reach the receriver part of the sensor, printer will report such errors.
Good luck.
Jan 26, 2008 | Xerox Phaser 6100/BD Laser Printer
Transfer belt errors
I saw this posted somewhere on the internet and it worked for me.
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. Put it all back together and hope for the best.
Sep 30, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
412 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
