Question about Canon LV-7215 Multimedia Projector
Canon LV 7215 lcd projector: border is not black it orange brown colored and causes contrast problems with picture
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Well, this could be attributed to settings, although if you've messed around with the settings for a while to no avail it could be another problem. Unfortunately, without much in the way of details, I can only make one suggestion.
It could perhaps be that your bulb has burn in. This happens with projectors over time, especially if a single image is left on too long (ie computer desktop or ppt borders)
I've also noticed that the lense can become burned as well, over time. Don't ask me how that's possible as I don't know enough about projectors to accurately guess.
Try cleaning the lense for starters, then consider replacing the bulb if that doesn't work.  You should take it to the place you bought it and they can tell you more concretely what the problem might be.
Caid.
Posted on Dec 30, 2008
Purchase Canon LV S3 bulb
the Original lamp for LV S3
USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Apr 02, 2014 | Canon LV S3 Lamp
Rectification of Power Supply Unit of CANON Projector Model No : LV -S4 Serial No : T701182A
the power supply unit is USD60
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
POWER SUPPLY PROBLEM
LV-S1 X1
power supply unit
price :USD70
Have a nice day!
Lampdeng Limited
Jerry
Power Supply Unit of CANON Projector LV-S4 COST PRICE
power supply foe lv s4
usd60
Have a nice day!
Lampdeng Limited
Jerry
Feb 15, 2014 | Canon LV-LP23 Projector Lamp for LV-S4
CANON PROJECTOR LV-S4 POWER SUPPLY UNIT
power supply for S4 ,Unit price is USD65
have a nice day!
skype:lampdeng
Canon lv- x5
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
Lampdeng Limited
Jerry
Jan 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
There is a blue and yellow shadow on a picture i can not achieve the white balance
the issue described is cause by a bad blue lcd panel. if you use a black/dark image, it will be quite evident. unfortunately you'll need to replace the whole prism block assembly (all 3 LCD's) to fix the problem.
May 31, 2011 | Canon LV-7225 LCD Projector
Our club owns a Canon LV-7240 which has worked OK. Last night we showed an NTSC DVD from Europe and no red showed. We could see what the colours ought to be on the laptop screen. On the big screen,...
Can't answer for the menu issues, but I can garuntee this is not a problem with brightness, contrast or sharpness, and very unlikely that you'll find a solution in the menu. What is likely is that the VGA wasn't plugged in properly initially. When the signal is going down the VGA it's broken up into 5 seperate signals, Red, Green, Blue and 2 sync signals. What is likely is that the green and blue pins havn't properly made contact either inside the projector or inside the laptop. This would also explain why it worked when you tried later because it made the connection properly. I would suggest trying again with the same laptop, if it does it again, try another PC without moving the projector or the VGA connector that's plugged into the projector. This will atleast narrow down your problem, but it doesn't sound like a problem with the projector to me. Also try plugging the laptop that wasn't working properly into a monitor (this will test the laptop)
Mar 25, 2011 | Canon LV-7240 Multimedia Projector
Canon projector Dim & yellow
Yes, thsi can be a problem with the projector bulb and you may need to replace it already..
Hope that helps.........
Oct 03, 2008 | Canon LV-7230 Multimedia Projector
Big Green Bar
Hi Tom017
Does this green bar show even when there is no signal inserted into the Projector ?
If it doesn't then you can try using a different cable - that should solve this for you.
If it doesn't then you might be in for a quite expensive Mainbaord repair or replacement.
Good luck and thanks for using Fixya !
May 06, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV-7215 Multimedia Projector Logo
153 people viewed this question
old marine
old marine
