Question about HP ze5468 PC Notebook
Premature shut off
My system shuts off after about two hours , the cpu fans are noisy and the under case gets very hot
Thinkpad A22m 2628-3SU laptop premature shutdown
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | IBM ThinkPad A22m 2628 Notebook
Tip
Fix OVERHEATING Notebook
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Come on and after about a hour are so it feel hot and shut down how do i fix this dose it need the cu fan replace in it
You likely have a bad fan, but download HWmonitor (http://www.cpuid.com/softwares/hwmonitor.html) and see what it's reporting under CPU temperature and fan speeds. If you really want to be sure, you can just pop open your case and see which fans spin up.
May 16, 2011 | Computers & Internet
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
Solution:
May 04, 2010 | Toshiba Computers & Internet
Computer frequently shuts down unexpectedly/ fans very noisy
You might have a cooling problem due to a fan malfunction. It is not clear whether it's the power supply fan or the CPU fan; in the latter case you might also have a thermal coupling problem. The symptoms you describe certainly seem to point to such.
My advice would be to replace the fan (or the whole power supply; you might also want to purchase a "Silent Power" unit for quieter computing). If it's the CPU fan and you are comfortable with, or know anyone comfortable with a bit of PC servicing, you might want to also unmount the heat sink from the CPU and replace the thermal paste between CPU and heatsink. Clean the heat dissipator (the black metal grille over the heatsink) with hot water and a bit of soap and dry thoroughly, or wipe it energically with a dust brush, before mounting the new fan on it.
Feb 28, 2010 | HP KQ499AA Pavilion Elite M9360F Desktop...
My laptop gets heat and shutdown
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
Feb 27, 2010 | Compaq Evo N610C Notebook
My fan is really noisy and the laptop is overheating. Most of the time it ends up shutting down and I wont be able to start it back up for at least an hour
The laptop is shutting down because the CPU is overheating (thermal shutdown) and if this problem is not fixed the CPU will eventually fail.
Replace the faulty fan and remove the dust from the heatsink.
While you are at it I suggest you apply fresh thermal paste on the CPU and hearsink.
Sep 30, 2009 | HP Pavilion Dv6910us Notebook
Automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Aug 01, 2009 | Acer Aspire 5315 Notebook
Vista 64 shuts down while playing games
Check for overheating problems
Check all fans including power supply one
Then remove fan from heatsink and clean out all fluff and dust
Vacuum out case all vent holes ans case fans
When playing games either CPU or Video card getting hot and closing down to protect system
Oct 23, 2008 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
HP ze5468 PC Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
