Question about Panasonic PT-56DLX25 56" HDTV
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
  • 1 more comment
  • extreme1957 Feb 22, 2009
    Panasonic PT-56DLX25 56 in. HDTV Television
    need the lamp timer reset thanks Harold
  • nikkie73 May 13, 2009
    HAVE THE SAME PROBLEM. HELP PLEASE...THE VOL/PIP/SPIT SOLUTION IS NOT WORKING.DO I NEED THE PT-56DLX25 REMOTE TO DO THIS? I AM ON A UNIVERSAL REMOTE
  • Anonymous Mar 25, 2014
    I need to know what malfunction 2 is
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Posted on Feb 27, 2009
During the installation of new bulb make sure your TV is unpluged from wall outlet, after fixing bulb reassemble your TV and plug your TV to the outlet. Now turn on your TV and once "replace bulb message" is gone, press the DOWN VOLUME button on your TV and at the same time press split button on your remote control untill you see the message about resetting of bulb meter.
Posted on Jun 08, 2009
This was the correct answer for me after reading 100 puch this pull that on the remote this WORKED
Posted on May 21, 2009
Ineed to reset the lamp timer on my panasonic pt-56dlx75-k tv I installed a new lamp
terryc43,
This should solve your problem.
1. Turn on the television.
2. Press the down button on the TV Display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating!!
hardrocko
Oct 28, 2010 | Panasonic PT-56DLX75 56" HDTV
Tip
Panasonic PT-61LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-61LCX66 Television
How do i reset the new lamp hours after installed the new one?
The reset instructions often are in the box with the replacement lamp; use those directions if you have them.
Try holding the Volume Down button on the TV while pushing the Play PIP button on the remote for about 5 seconds. If that doesn't work, try the Split button instead of the Play PIP button on the remote. You should see a message that the Lamp hours have been reset before you release the two keys.
I hope this helps.
(make sure the cover is properly attached before trying the reset.)
Sep 15, 2010 | Panasonic PT-56DLX25 56" HDTV
How to reset lamp time on panasonic hdtv pt-56dlx25 after replacing lamp?
Hi there
To answer your question;
Hold the volume down on the tv set and the 0(zero) button on the remote for more than five seconds.
You should then get a message saying that the lamp timer was reset to zero
press enter and that`s it
Hope this helps Cheers
Apr 21, 2010 | Panasonic PT-56DLX25 56" HDTV
I replaced the lamp and am still getting the message after holding down the vol control and split button. Should I unplug the tv and redo the lamp?
Remember vol down on tv and split button on remote at the same time for 10 sec until you see a message saying "lamp timer has been reset."
Mar 01, 2010 | Panasonic PT-56DLX25 56" HDTV
I need to reset lamp using my remote for my remote
could be getting to hot clean vent holes move back from wall a little bit.lamp may need replacing.try removing and reinstalling lamp
Feb 18, 2010 | Panasonic PT-56DLX25 56" HDTV
How to reset timer on PT-56DLx25 I got the new lamp,but no instructions are in the box on how to reset the timer.
Since all the other solutions were not very specific for some reason. HERE is the right procedure for model # PT-56DLX25.
Press and hold the Volume Down button (On the television set itself, not the remote) and the split button on the remote control simultaneously for atleast 5 seconds and you will get the message "Lamp timer has been reset to 0. Your welcome :)
Dec 26, 2009 | Panasonic PT-56DLX25 56" HDTV
How do i reset the hour meter on my panisonic PT56DLX25 PT-56DLX25 after i have replaced the bulb?
You did not specify the model number of your set, but, I have the LCD reset proceedure listed below for you.
Panasonic Lamp timer reset.
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
Oct 17, 2009 | Panasonic PT-56DLX25 56" HDTV
How does one reset the lamp timer. modelpt-56dlx25
Panasonic2.gif Lamp timer reset.
To reset the lamp timer
asnowman
Oct 12, 2009 | Panasonic Televison & Video
Panasonic pt-56dlx75
Thanks!
Keith
Jul 08, 2008 | Panasonic PT-56DLX25 56" HDTV
Panasonic PT-56DLX25 56" HDTV Logo
486 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
