Question about HP LaserJet 4 plus Printer
How do you clear the stored memory?
I hooked up a USB printer to my Linksys Wirless Print Server. Like a ding bat I forgot to change the Port Settings from Parallel to USB and then sent a request for a print test. Of course the computer is only as smart as the programer and it was sent to the wrong printer. Now my Laser Jet is trying to print sheet after sheet of garled info that was supposed to go to my Epson Stylus Photo R200 and I can't get the memory to clear. I have tried turning off the printer and even unplugging it for a day. HELP!
  • Laura Sisk May 02, 2007
    Clearing the memory in the Printer Folder was the first thing I did. Sorry I left it out as one of the steps I took. The HP Laser Jet 4 has its own internal memory and that is what needs to be cleared.
  • NISTMary Jan 23, 2009
    I have the same problem. This is not as simple as clearing the print queue. My printer continues to print garbage as soon as it is powered on ... whether it is hooked to a PC or not!!
    Problem Solver:
  • 17 Answers
The problem is not with the printer, but with your PC print queue still having the outstanding print job. Anytime you power off a printer, it automatically clears it's internal memory. Depending upon which operating system you are using, you need to go to the Printers Folder, open up the queue, and delete the print job there. Once the queue is clear, that should take care of it.
Posted on May 01, 2007
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to microsoft.com and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
Will linksys wps54g print server work w/canon pixma ip5000 printer?
this product has a USB port on it so you can plug any Usb printer to this and it will work.
Dec 07, 2009 | Linksys Wireless-G WPS54G Print Server
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Will linksys wirless g print server woork with epson cx4800 printer
Yes,
This is a USB All-In-One printer and the Linksys Wireless G Print Server supports USB pprinters.
However,
For the cost of the Linksys print server, you can purchase an Epson NX515 that has built-in WiFi. It would also be less hassle if the Linksys/CX4800 has a problem. You would not know which device is causing the problem.
Oct 08, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Able to print documents on HPc4385, but cannot print photos
When you were connected with a USB cable was it connected to the computer your using as local? Are you using a wirless print server? Possible corrections are in the properties of your print setup. You can change the spooling properties to print immediately to require less memory.
Aug 30, 2009 | HP PhotoSmart C4385 All-in-One Printer
Well you please tell me default IP address of LINKSYS Wireless-G Print Server
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
  1. Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
  2. Be sure also that your printer can print when it is connected directly to your computer.
  3. Click on Start go to Printers and Faxes.
  4. Right click your printer and go to Properties.
  5. Click on the Ports Tab on the top.
  6. Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
  7. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  8. Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
  9. Select Custom, click Settings.
  10. Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
Jan 22, 2009 | Linksys Wireless-G WPS54GU2 Print Server
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Linksys print server Model EPSX3
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Nov 05, 2007 | Linksys EtherFast 10/100 (epsx3/uk) Print...
HP LaserJet 4 plus Printer Logo
468 people viewed this question
Clive
Clive
