My Panasonic CS-E24HKR airconditioner sometimes shuts down
When I try to restart the unit the timer light sharts flashing and the unit will not start. The only way I have found around this is to turn the mains off to the airconditioner, wait ten seconds and turn the mains back on. By doing this I am able to get the unit to work for another couple of days. It only seems to be happening on the cooling cycle, but I am not using the heating cycle much.
  • danhymas Jan 13, 2009
    My CS-E24HKR is doing the same and it told me it was a F99 Error, What does this mean
  • raeme07 Feb 10, 2009
    I'd like to thank the experts for the zero assistance offered, you are no help at all!
22yooper
  • 828 Answers
SOURCE: Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Posted on Jul 18, 2008
rockitman187
  • 2559 Answers
SOURCE: I have a Carrier Weathermaker
Emergency heat is made for this kind of situation.So yes you can.
now for the codes.
code 12= Blower on after power up
code 31=High heat pressure switch or relay didn't close or reopened
code 32=Low heat pressure switch or relay didn't close or reopened
code 33=limit circuit fault(Flame rollout switch is open)
code 41=board fault
code 42=control lockout
Please rate this solution
Posted on Jan 17, 2009
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
relaga58
  • 158 Answers
SOURCE: My panasonic cs-e12hkr airconditioner will only
try resetting by turning power off and on
Posted on Nov 25, 2009
SOURCE: The operation and timer lights on my Fujitsu split
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Posted on Nov 23, 2010
Panasonic CS-E24FKR Airconditioner keeps turning off. Error code 15 H
Is the air-conditioner plugged into an extention cord or directly into the wall outlet???
Aug 20, 2016 | Panasonic Heating & Cooling
My air con just suddenly stop blowing air and the timer button just starts blinking. every time i switch on the aircon it will auto shut down and the timer button lights up please help me to fix it.
Owner's manual? troubleshooting? Possible it's smart enough to know you have an air filter that needs changing or cleaning.
No manual? Try MFG web site, or email their customer service, or try manualslib.com
Apr 02, 2015 | Panasonic Heating & Cooling
Panasonic cs e9nkr aircon. Shuts down timer continuously blinks. Checked for fault codes h00
I haven't got the service manual for this but the error codes should be on a sticker behind the front cover. Take that of and it will guide you to the fault.
Feb 19, 2015 | Panasonic Heating & Cooling
I have a panasonic split system in the kids bedroom its an ECONAVI indoor unit is CS-E9NKR we have not used this A/C since last summer, now the compressor will not start, only the indoor unit operates
Typically on a mini split the outdoor unit is powered and the indoor unit gets its power from the outdoor unit. If the unit is a year old you might have lost your charge. Look at the connections at the indoor unit and outdoor unit. You will typically see oil or a dirty area on your copper were there is a leak.
Nov 16, 2013 | Panasonic Heating & Cooling
I have a Panasonic Invertor in my office with no manual. The timer light is continually flashing and the unit will not operate. I have tried re-setting the timer to no avail. My remote has an on/off orange...
I have looked through the manual but I do not have a device to test what your issue may be but here is a link for the manual. I hope this can help you out.
https://support.panasonic.co.nz/docstore/CS-ME10DTEG%20Operating%20Instructions.pdf
Mar 01, 2011 | Heating & Cooling
Hi, the timer light keeps flashing and the unit isn't operable.
As you have not mentioned any model/BTU/error code, i could help you only by giving this following site;
http://www.haddocktechnics.nl/panasonic/Servicemanuals/Servicemanual Panasonic CAS (HP) CS-F14 18DB4E5
thanks.
Feb 02, 2011 | Panasonic Heating & Cooling
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
Heating & Cooling Logo
269 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
