Question about Kenmore 22422 Top Load Washer
I think the belt is loose i dont know what it connects around.
The washer makes a winding noise but doesnt move it just the belt?...and if so...where does the belt connect to?..its a kenmore 70 series model #82874120
    Problem Solver:
  • 7 Answers
If it doesnt spin its ur coupler 4 dollar part easy fix or 100 bucks some body will come 2 u and fix it
Posted on Jan 07, 2009
I have a 2001 Intrigue, its makes a "winding up" noise when i start up' but goes away a few mins later.. could that be my Air pump?
i think the noise you heard is from a loose belt. you can visually check it while the engine is OFF.. check some of the belt tensioner or the belt itself try to full it giving special attention to FAN belt.. i think thats the culprit..
Sep 22, 2013 | Chevrolet Lumina Cars & Trucks
Clicking when drum rotates
Try running for a short time with no load, it looks like you have a foreign object stuck inside.
Aug 30, 2008 | GE WCVH6260F Front Load Washer
Glws1339cs1, started making noise like a belt was slipping during the spin cycle
Hello Bill Johnson - Is the washer draining or spinning? Could it possibly be a humming noise? If it is not doing either or and making a humming noise then it could possibly have a restriction in the drain line. Or either the belt is loose and will have to be put around the transmission and then spin it on to the motor or there is an issue with the lower/upper bearing. I would suggest contacting a professional to move forward accurately to properly diagnose/repair the washer.
Nov 12, 2012 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
When I push the start button, the drum will not always turn. Sometimes it make a buzzing noise and it smells like th emotor is heating up. after a few trys it won't even try to start. I took the dryer...
Sounds like the centrifugal start switch in the motor is malfunctioning -- the motor is running on the start winding and not switching (via the centrifugal start switch) to the run winding. The smell is because the start winding is overheating.
The centrifugal start switch is inside the motor on the end of the shaft with the pulley. You should be able to see it. Give it a good cleaning and lightly lubricate it. Move it back and forth to get it moving freely while cleaning / lubricating.
If this doesn't clear up the problem, the motor winding could be shorted already or the centrifugal start switch could be damaged beyond help by cleaning / lubricating.
More info, let me know.
Feb 08, 2011 | Maytag Dryers
Motor or clutch ?
Clicking noises are most often associated with bra wires , sticking in between the drums , have a good look all around the inner tub with a torch if you spot a wire sticking through carefully pull it out with pliers but dont loose it , once it goes all the way through it is neccesery to completely dismantle tub assy to remove it.
Nov 03, 2009 | GE WBSE3120B Top Load Washer
Washes but doesnt drain or spin
Unplug Washer
Shut of Water hoses to Washer and Disconnect from Washer.
Turn washer around and remove back cover.
Look inside fro the Belt it should either be Loose, or Broken. Just Replace.
Hope that helped
Please Rate Me
Apr 29, 2009 | Washing Machines
Hoover Wind Tunnel 2 Making Noise While Operating
sounds like your brush roller bearings are going bador cloged up with carpet strands if you can take the bottom open and remove the brush roller look at the ends and see if you see any melted plastic or see if the ends feel loose like wobble back and forth.once you take the roller out turn the vacuum on and see if you hear the same noise.also check the belt and see if it looks burnt on the inside of the belt. and does it look stretched out .the belt might be stretched out and fluttering when running.feel free to cal me and maybe i can help you further with it.i'm not one of the techs .i'm just trying to help people.i don't charge for my advise
Apr 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Whirlpool Lsq8243h
unplug washer and lean washer back aganst wall,put something under frount of washer.So you can see under washer .Look and see if the belt are still on the pully or if there streached out (not tight) fix accordingly.
Jan 17, 2009 | Whirlpool LSQ8243H
Washing machine knocks in cycle
if its a whirlpool top loading washer, sounds like a bad motor coupling.( the machines equivilent to a belt.)
Oct 25, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
111 people viewed this question
Sal De
 Brian Main
Brian Main
