Question about SAMTRON 55V 15" CRT Monitor
Samsung samtron 55v display problem
I was using samsung samtron 55v monitor with Windows XP. Recently i upgraded to vista. The problem is that on the screen no red color is visible. The red color is being replaced by greys. All other colors are displayed correctly. Plz help....
    President:
  • 414 Answers
Assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Posted on Oct 28, 2009
I have problem of color code of display cord i dont no color code
Posted on Mar 02, 2009
    Problem Solver:
  • 5 Answers
Please check the vga cable in the monitor or check the monitor video board with the help of service enginners dont open without service people because monitor produce heavy voltage
Posted on Jan 02, 2009
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
I need display of 56v samtron monitor
Did you check the adjustment setting on the brightness and contrast?
These two setting can be moved and stop the CRT from displaying,
Please move these two setting to MAX and see is there any image on the display.
Jan 31, 2011 | SAMTRON 55V 15" CRT Monitor
I can't open Monitor
there will be 2 plastic lugs on the top of the monitor. using a flat blade screwdriver you can undo these
May 12, 2010 | SAMTRON 55V 15" CRT Monitor
I can not adjust the resolution in my samtron 55v i run xp on my pc
In Xp right click on the desktop and select Properties->Settings->Resolution. Here you will get all the options that the combination of your display adapter and monitor can take. select any that you want and Windows will show to the new resolution and ask you if you like it. Accept if you like it else Cancel it and select one lower or higher till you are satisfied. Go up one notch at a time.
Dec 07, 2009 | SAMTRON 55V 15" CRT Monitor
I have a problem with hp crt monitor can't display caracter but only light like rainbow on the screen can yaou give me solution please thanks
Hi...there,
Well, it is time to upgrade to a LCD flat screen monitor... The one you got it's busted.... You get buy one 19" LCD monitor less than $200...
Dec 01, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung SAMTRON 55V
just find it on http://www.eserviceinfo.com/download.php?fileid=4374 just vote for me so that i can help u again
Aug 29, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
Swapped colors in the monitor...
Sounds like you have swapped pins 2 & 3 in your VGA plug.
Sep 01, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
258 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
