Question about LG VX6000
Flash stuck on LG VX6100
My LG VX6100 accidentally went through the washing machine! After drying out a few days, everything started working normally except the LED flash stays on full time and therefore runs down the battery very quickly. Help!
If it survived one dunking it will most liklet survive a second SOOOOO. I am into R/C stuff and when our gear gets dunked we rinse it out with ultra pure water, Deionised/distilled water if you can get it. I think that the detergent in the washing machine may have left a residue and be affecting your electronics so if you wash it carefully in distilled water (yep dunk it again, crack it open and wash it all inside)to get rid of the detergent residue on the board (note REMOVE BATTERY). Afterwards dunk it in methylated spirits (test to make sure it wont affect any plastic parts first)to remove the water and leave to dry in a warm spot for a day at least. 2 years ago I dropped a $500 transmitter in a dirty dam (Acid /fuel/road runoff)and did exactly this and its been fine ever since. Worked the next day in fact. Its not a mobile phone but its always worth a chance. Once you've finished you may want to take it apart after you've tested it if its going and spray the board with CRC 226 circuit cleaner and water repeller. I've got it on all of my R/C gear and it gets regularly soaked for up to 1hr at a time in muddy water and is all fine.
Posted on May 08, 2007
Model #1045 went dry, after filling, it started flashing 20 even after I filled it. I unpluged it and waited for a few minutes, but it continues to flash 20. What should I do now.
please go to the manufactures website and download the user manual its normally free and go to the trouble shooting guide for the answerer eric
Dec 26, 2017 | Washing Machines
Tip
Thanks for the advice, it worked! For a few days I tried to cancel the blinking...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Sep 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Lg vx6100 won't turn on or charge
There may be liquid damage present. First using a flashlight, inspect the battery contacts and data/charging socket for green mold/water damage. If nothing unusual is discovered you could disassemble and inspect the inner circuit boards for white residue that would be left behind from water calcium, clean the calcium from the circuit board with a slightly wet toothbrush and dry with compressed air or a hair dryer.
Dec 22, 2013 | LG VX8300 Cellular Phone
My SD card went through the washing machine. Is it ruined?
Let it dry out in a warm place for a few days. Then try it out, if it does not work then it is broken.
Sep 25, 2010 | SanDisk 2GB Secure Digital Memory Card
My camera was accidentally thrown in the washing machine with laundry and was washed. Have let it sit for a few days to let it dry out and now it won't turn on. Is there anything I can do to fix this...
A few days is nowhere near enough. If you've tried to turn it on, the circuits are probably fried. The soapy water would definitely leave a film over everything including the inside of the lens elements. You should have buried the camera in a bowl of dry rice for a couple of weeks before even attempting to turn it on. Even then, the chance of a complete recovery would be less than .00000000000000001%!!! At least we learn from our mistakes.
Aug 28, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
Dropped LG shine into a bucket of water
if it was just pure water leave the battery out and let it dry for a few days in a warm dry place if not wash it out with warm water and let it dry this has worked for me a few times in the past hope it works for you
Oct 31, 2009 | LG Shine KE970 Cellular Phone
LG RUMOR went through washing machine!
you are lucky this time your phone is working tis time your phone is working and there is no way you can get your screen back but remember next timeif your phone goes through wash do not start it immediately let dry for atleast 3 days or else if you start it short circuit takes place for.now get a new phone for yourself
May 18, 2009 | LG RUMOR Cellular Phone
Jasjar-no sound-after spilled water on it.
I think you still have a good (not 100%) chance of saving it. It usually takes much longer than 1 day to dry out electronics that are still intact. I would open it up and let it dry. Otherwise, see if have a nerdy friend who has access to a non-humidified incubator and leave it in there for a few days. (that's how I salvaged a phone that went through the wash!)
Aug 31, 2008 | i-mate JASJAR Smartphone
Camera flash stays on...
You probably have a short somewhere in the phone. Open any access points, take out battery, mop up any visible liquid with a q-tip. Keep it in warm very dry area for 3-4 days (lots of air movement will help) and it will probably dry out inside. Connect battery again briefly, if flash still burns, leave for another few days. Fan heater on very low may help here, put the phone about where you would put a baby. Still not right, you probably have a fused contact point and need a repair.
Mar 02, 2008 | LG VX6100 Cellular Phone
Open Questions:
LG VX6000 Logo
168 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
