Question about Adtran Atlas 550 Router
Adtran Atlas 550 alternatives
Greetings; I have four Adtran 550's (one at each site) with a T1 Connection providing data only communications to each location. I am interested in replacinf these devices with newer less exspensive alternatives. Question 1: Would a Cisco 1720 provide a simple soltution for terminating a T1 to Ethernet 100 Mps. Question 2: If this would not be an option, what Cisco box would provide the needed termination/routing? Question 3: If a Cisco device could do this would it be necessary to replace them at both locations or could it communicate with the Adtran device? Thank you in advance for your assistance!!!!
  • inner_silence Feb 24, 2012
    Hi Ryan,
    I purchased a used Atlas 550 for study purposes however the seller didn't have the console cable. If you've one spare and willing to share at a price or free, let me know at "nice_chatin@yahoo.com". I'll appreciate the help.
    Thanks,
    Kapil
    Problem Solver:
  • 12 Answers
1: Would a Cisco 1720 provide a simple soltution for terminating a T1 to Ethernet 100 Mps I recommend a 1721 2: If this would not be an option, what Cisco box would provide the needed termination/routing I recommend a 1721 3: If a Cisco device could do this would it be necessary to replace them at both locations or could it communicate with the Adtran device. It depends on the topology of how your sites are interconnected to each other. Please describe in greater detail.
Posted on Jul 08, 2007
SOURCE:
How does and Atlas 550 split to analog
The Atlas 550 is modular, and can break out the 23 channels as BRI or FXS. Since you want 23 analog lines, I presume you want regular 2-wire phone lines (aka, FXS lines). The you that by using 3 "Octal FXS" modules (8 port modules) in addition to the T1 module.
Read more here: http://www.adtran.com/web/appmanager/portal/Adtran?_nfpb=true&partNumber=1200305E2
Nov 21, 2011 | Adtran Atlas 550 (4200305L3) Multiplexer
I have a problem with a Mitel sx2000 PBX which seams to be causing our line supplier problems. They say it is showing slips on the line and we need to have the clock set to theres and not the internal...
Your DSU/CUS can set clocking/timing from the local central office (CO) or internal.
There are MANY external DSU/CSU in the market.
Example: Adtran and Lucent
Please reply with what type of T1 DSU/CSU is connected to your unit.
==== If your setup does not use an external DSU/CSU then look for setting for your internal T1 card.
Are all cards on the same rack?
Grounded?
Jan 05, 2011 | Mitel SX200 480 Port T1 Adaptor...
Need the remote codes from a bdp s-550 to program another remote
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Mar 20, 2010 | Sony BDP-S350 Blu-Ray Player
Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Lost my phone W550I
Greetings.
Its not advisable to post your imei. Pls inform your service provider about this so they can give you advice as to how to recover or at least disable your sim/phone.
Jan 12, 2009 | Sony Ericsson W550i Cellular Phone
T! lines
A T1 line is a dedicated connection to an Internet backbone router. Typically a T1 line is for major businesses and school campuses. A T1 line is capable of handling 637 simultaneous VOIP connections with full-duplex connection.
How many computers do you intend to have connected to this network? Even a fractal T1 is very expensive. A full T1 connection can cost nearly 25K per month usage. A T1 line will need to be installed by your ISP provider and this too will cost a significant amount of money and it depends on how close your network connection will be in relation to the main network trunk-line.
If you trying to connect a T1 line to a Belkin 54g wireless router, you are way out of your league. I have worked for several networking firms in the Atlanta, GA area and we never had more than a fractal T1. Most small to midsized networks (up to 100) users can be accommodated with using a DSL or Cable Internet connection with a dedicated firewall and router/switch to handle the network traffic. Unless you are willing to pay for a T1 fiber optic line to be run from the main trunk line to your place of business or home, you will be fine with a high speed cable internet connection from an ISP provider like Comcast of Qwest here in the US. Fiber still has an installation cost of about $10,000USD per 1000 feet.
Hope this helps to clarify your problem.
Cheers,
Keith
Oct 23, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Sep 19, 2008 | Computers & Internet
Help!
I suggest trying MyPhoneExplorer which is a software developed for backing up SonyEricsson handsets.
Doenload and install it. Then connect your phone to the PC via DCU-60 cable. (It is the gray USB cable provided with the phone.)
Then check the connection settings so that correct connection type is specified. Otherwise your handset will not be recognised.
If your device is recognised, it will start backing up your data. If it is not, I am sorry that I know no other alternatives to back the data up.
Hope this works for you,
Greetings,.
Dec 28, 2007 | Sony Ericsson K750i Cellular Phone
Adtran Atlas 550 Router Logo
289 people viewed this question
Top Adtran Computers & Internet Experts
Vincent_G
Vincent_G
matt
matt
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
