Question about HP DeskJet F380 All-In-One Printer
Hp deskjet 380 all in one not vfunctioning
My deskjet hp 380 all in one in not taking command for printing. Cartridges were changed and new were installed. How can I continue printing from the same. I have lost original printers software.
pranesh
  • shanisherif Feb 10, 2009
    i need a setup to install this printer in my pc
  • Sis Pastor Feb 11, 2009
    My hpdeskjet f380 will not respond to "print" printer status: Error Offline
    Scholar:
  • 82 Answers
Uninstall the driver, in case any remaining
from Add Remove Programs
Please find the link below from where u can get the software drivers for Hp deskjet F380
Please choose the Operating system (OS) of your PC/notebook and then download the drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=vn&lang=en&os=228&product=1128296&
Do not plugin the printer USB cable, just turn it one
and while setup continues It will direct u to insert USB cable
Plug in the cable only when directed
i hope this will solve ur problem
Posted on Dec 30, 2008
Black cartridge (HP21) will not print or prints faint 2mm strips (like a pedestrian crossing) of a broad black test piece on my HP Deskjet 2180 Desk. Colour (HP22) is OK. Cleaned cartridge manually per HP...
This type of cartridge has the printing head in them - the possibility that all 3 ones are clogged is extremely low. If you get a bad printing with them it's because the heads are incorrectly commanded - either the pin array that transfer the command is damaged and they will have to be cleaned and fixed or the processor of the printer is dead, and the printer with it.
Jul 09, 2011 | Office Equipment & Supplies
When print to the printer then printer take the paper and print the paper but when paper out the printer then paper is blank
If the printer accepts the commands from the pc and acts like it is printing, but no ink appears on the page, it probably means that the ink has run out and the cartridges are not supported by the printer, ie, refilled cartridges. If the cartridges are relatively new and are HP cartridges, the problem might be with alignment of the printer, but that is not likely. The most likely is that the cartridges are bad and new ones are needed. In either event it is probably too expensive relative to the cost of a new printer to try to fix this one because if the cartridges are not bad, you risk wasting the money buying new ones when the printer repair is not cost effective. One thing you might check is that the paper path is clear so that when the paper is fed through it does not get held away from the print head. Also check that the paper is following the correct path as it is printing. In any event, these printers are not expensive enough to spend much time trying to repair them.
Apr 19, 2011 | HP DeskJet 810c InkJet Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
HP 380 No Ink problem
Follow the cleaning procedure shown on the HP Website to clean your ink cartridges and cradles.
Go to support.hp.com and put your model, look for the troubleshooting section.
Nov 04, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
New HP printer Deskjet F4180 will not print
Hey
Try to take the cartridges out and clean the cartridges and cartridge holder with damp clothe
now shake the cartrdges and clean it agaian with damp cloth
put the cartridges back in and see if it works
Sep 18, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Cartridge empty light
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
Run your printers alignment test
I would suspect number 1.
If you found this information useful please click below
Aug 12, 2009 | HP DeskJet 1280 InkJet Printer
Paper gets stuck, eject indicator keeps blinking with out any effect on pressing it
its the problem in the main board of the printer that has shorted out the new colour and black cartridge in your printer which you installed.or may be one out of them.it happens some time.so you will have replace the cartridges 1 by 1 with new cartridge and check out.if still the problem then replace the board.that costs $12 plus shipping. mostly the cartridges have shorted out and replacing the cartridges will solve.
May 08, 2009 | HP DeskJet 610c InkJet Printer
Auto test page on the HP F 380
I don't know this personally, but you should be able to hit the power button and turn it off right after you load the cartridges. then power back on. That might do the trick.
Dec 08, 2007 | HP DeskJet F380 All-In-One Printer
Printing problem
You have either a clogged colour print head or a non-functioning print cartridge (only one colour working). If the printer has separate cartridges for different colours (and black) you can do a partial swap, replacing the ones that have failed, but start by running the command CLEAN PRINT HEADS from the printer options or controller panel, and watch for the quality to improve. You may have to clean the heads two or three times. If no change in the quality after two flushes, replace the cartridges with new ones.
Good luck...
Nov 16, 2007 | HP DeskJet 610c InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
213 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
