Question about Baby Gear
Need instructions on putting together
I am trying to figure out how to install the straps. None of the straps are installed. I also could not figure out how to remove seat cover for washing. It was manufactured 05/22/2002 and has a code of AO3B.
  • 1 more comment
  • Anonymous Jan 05, 2009
    I disassembled everything trying to get straps off to wash with the cover after my son vomited all over himself in it. I got the straps back on just fine, but I'm having trouble with the mechanisms for tightening/loosening the straps.
  • lsondervorst Jan 05, 2009
    I have exactly the same problem!
    I just called maxi cosi HO to ask for guidance and they just told me off for having removed the belts/harnesses, insisting I should buy a new one.
    I don't even know how to put the belts back on... any help appreciaed
    thank you
  • Anonymous Jan 06, 2009
    I took off the cover to wash it an can not replace it.
Here's a link to a photo of the Century Breverra. From the photo at this website, I was able to figure it out. http://www99.epinions.com/review/Century_Breverra_Ascend_Sport/content_22722481796
First, thread the strap through the piece that clicks into the crotch point. Then, thread the strap through the **** on the seat just to the side of the crotch lock. Run the strap under the chair and through the **** on the opposite side of the bottom of the lock. Then, run it through both sides of chest lock, up through the shoulder points and lock it in the back. You're done!
It's not very eloquent but hope it helps!
Posted on Jan 14, 2009
Assembly instructions for robotime walking t-rex dinosaur model d210
I would like to know the same, We have been trying to put one together and half the instructions are correct, then it changes and none of the pieces are the same as the manual? Are you having the same problem?
Dec 14, 2012 | Dinosaur Toys
Put together starter system need a diagram on a valor tropic 121 wall gas fire
You should be able to download the installer instructions on
Valors website, the information can be found here
under Trade then installer guides
www.valor.co.uk
alternatively new Valor Gas Fires
Jan 02, 2011 | Valor Toys
Looking for instructions for assembling a costco car seats straps
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
http://www.coscojuvenile.com/Instructions
GOOD LUCK!
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Jul 03, 2010 | Cosco High Back Booster 22-200 /22-207
Evenflo carseat,can't figure out the straps after washing
You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
Jun 17, 2009 | Baby Gear
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
How to change Mini Em-Tor Fill Tube Assembly on Kirby G4
You will have to remove bag strap. You can try to save old strap (see instruction here) or you can cut it. Install the bag on the new mini-emptor just like it was on old one (strap goes over both layers of vinyl). Use a long cable tie instead of the strap if you have damages it or your old bag strap. If you are using old strap you may have to use pliers to get it in all the way.
Oct 27, 2008 | Kirby G4 Bagged Upright Vacuum
Need instuctions
washed the cover , now i am trying to put it back together.
Feb 24, 2008 | Cosco Alpha Omega Elite - Hammer Print
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Baby Gear Logo
461 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
