Question about LG RC797T
LG 6710CDAK05A not playng DVD
The power went out and now my DVD won't play DVDs. It reads Unknown Disc. The setup function will not allow me to Disc Initialize either. This has happened before but the DVD player started playing again. I didn't do anything.
What can I do to fix it? I tried going back to factory settings but again the player will not disc initialize. There is nothing in the manual about this problem either. If I need to enter a code into the remote how and when and what code do I enter?
  • 46 Answers
SOURCE: LG DR275 Initialize problem
hello..Carol..please refer to your user manual and look in the chapter that includes "how to" maybe you don't have to manually initialize the disks..this will be done automatically...keep it easy...please tell me how it went !...good luck...Ron
Posted on Mar 07, 2008
SOURCE: LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Posted on Jun 05, 2008
  • 253 Answers
SOURCE: eRROR-No DIsc
try going to LGs website and look under support/downloads for a Firmware update, or any other updates, and install them (usually by downloading a file, then burning a DVD or CD on your PC to insert in the player.
If this helps solve your problem, please give a fixya rating, everyone of them helps. Thanks for the question
Posted on May 27, 2009
  • 788 Answers
SOURCE: Initializing discs
If you are using the same OS and have made no changes to software, it sounds like the drive may be faulty.
Try a disk cleaning kit and re-install the software for the program you are using.
Example, Try NERO or some other program after cleaning the drive.
Do a un-install of whatever program you may be using and re-install it.
If you can rely on the software, then the drive is probably at fault and should be replaced.
Look in systems information, under hardware configuration and look for problem devices.
Hope the helps.
Try it, it may work !!
John Ray
john@johnrraycomputer.com
Posted on Jun 29, 2009
SOURCE: My LG RC797T DVD deck
im sorry i dont have a solution to this problem, but i tried the exact same thing and got that 0xE0 key problem, so my dad and i decided to unplug the unit and plug it back in and now the unit will not respond to the remote. did you have this problem at all? and what did you do to exit the setup screen?
Posted on Dec 28, 2009
After warranty time expires (2yearsd) my LG LRY-517 DVD combo recorder/player start to make randomly disc reading errors. During half year things has going worse. Now the situation is that it does not play...
Use lens cleaner disk to run many times. It cleans the lens and also runs cd on the disk which eventually will get rid of moisture on the circuits and restore your dvd recorder on the LG unit.
Mar 11, 2011 | Televison & Video
DVD won't play
Netflix doesn't know what they're talking about. I looked it up - your DVD player doesn't have an autoplay feature. Can you try the DVD on another DVD player. Computers DVD drives generally read them differently - and decode them differently, than a regular DVD player. Also, if your DVD drive is a writable drive, it will have a stronger laser than your DVD player. I think it's likely the disk is damaged, slightly. If you cleaned your DVD's laser, it might be able to read it well enough to play - or it might not. I started having problems like this with a few of my own DVDs before my DVD player's laser went out. Basically it's a combination of laser quality and disc quality. If it remains just this one disk, I'd suggest leaving it alone. But if you start running into this problem on other disks as well, you'll probably want to have the laser replaced in your DVD player.
Aug 14, 2007 | Amphion Mediaworks S99 DVD Player
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
My dvd player plays cds but wont play dvds says disc error or unknown disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
My LG DVD RECORDER, MODEL RH7500 won't play DVDs.
Check the model specifications for your device. Some players will only accept DVD-R and not DVD+R or not DVD+RW discs. I know it all seems the same, and it's very frustrating, but many companies restrict the type of discs they will allow. My player does +R but not -R. It should still be able to read DVD discs that you made yourself, but they will be of a different type.
Nov 03, 2009 | Televison & Video
Player will not read dvds
Get into the Service Menu by entering 1397139 on the remote control like you did before and restore the original factory-set values stored in flash-memory back the way they were. One you do this your unit will function properly again. mikeadams110@yahoo.com
Original factory-settings
Option1: F2
Option2: 15
Option3: 93
Option4: CF
Option5: 94
Option6: C0
Option7: 04
Option8: 15
Oct 30, 2008 | LG RC797T
Wont play dvds, only cds, music and photos when dvd placed in tray, goes through reading process, then ejects tray with an on screen message, unknown disc! With all discs not a certain few. when a blank...
DVD & CD use different wavelengths for the read head. I suspect that the blue laser is out of alignment or otherwise in need of repair.
PhotoCD is a format.
Jul 20, 2008 | LG Televison & Video
LG V692wk won't play DVDs
A faulty laser or the connection could be breaking!
May 17, 2008 | Televison & Video
MODEL LG RC299 NOT READING DVD VIDEO'S. ERROR COMES UP "UNKNOWN DISC.PLEASE CHECK DISC". PLAY'S OK PREVIOUSLY RECORDERED DISC'S,RECORDERED ON THIS UNIT.
I also have this annoying problem - but I bought mine new on ebay and have zero after-sales support. I have tried all the hacks I cna find over the last 12 months and when I am finished, the messages all say 'congratulations, you're now region free'. But even the local DVDs don't work. Disc ejects itself with irritating message 'unknown disc'. Does anyone have this problem who has a SALES RECEIPT from an authorised LG dealer? If so, can you jump up and down with LG until they offer a solution? Thanks!
Mar 17, 2008 | LG Televison & Video
No disc / Unknown disc type
I had the same problem, some dvd-r's went faulty when the RH-299 couldn't finalize them. Problem fixed when the DVD readhead was replaced.
Feb 04, 2008 | LG RH299 DVD Recorder/VCR
LG RC797T Logo
Computer Repairing
Computer Repairing
