Philips pt4873 turns off and sounds like big spark inside the back of it its 7years old how can i fix myself got no money
  • 177 Answers
If you need more Information ask
Ecollier2012.Has more information then i do.
--P3NGYJ03
Posted on Dec 31, 2008
My son's 2003 Trailblazer recently died while driving and key wouldn't turn either way. It sounded like the alternator was shot so I removed it and had it checked. It was junk. I replaced it and now I...
sounds like the shifter might not all the way in Park and that the tumbler might be having problems get it checked out cause could be big money if it don,t get looked at soon
Feb 27, 2015 | Cars & Trucks
Electricity problems won't let the engine start. the only thing that turns on is the inside light of the car but not the headlights, the radio, or the engine. at first, it would make a sound like if it...
start by checking all cables that come off the battery and make sure the terminals are clean and tight,then chase them down to the starter,make sure all connections there are tight.even the ground from the bat.check all your grounds,check all the fuses.check the ignition moduel its on the steering column or around there cant miss it its got a big connector to it.
Aug 10, 2010 | 1984 Chevrolet Camaro
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big...
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Jul 01, 2009 | Philips 50P8341 50" Rear Projection...
Philips 42" PFP5332D/37 turns on then cuts out on pic and sound
It sounds like your High Voltage transformer is arcing.
Sometimes it can be repaired if not it is an expensive fix.
If you can see in the back of it look for sparks inside but do
not remove the rear panel, you can get zapped with 40,000 volts!
Mar 26, 2009 | Philips 42PFP5332D 42 in. Plasma...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
TV won't turn on power shuts off when hit remote and manuel poweron switch/
How old is this TV?
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like Module Exchange at 972-298-1212
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Jan 14, 2008 | JVC AV-32730 TV
No picture or sound just a high pitch beeping noise
Your problem is a bad sweep power supply or the horizontal sweep circuit has a short in it such as a bad horizontal output transistor as well as the high voltage flyback transformer. These are not problems that should even be concidered to be repaired or attempted to be repaired by an untrained person in solid state electronics. Please seek out a trained service person to estimate the TV for you as there are no user parts inside this set, and a TV set is not a place to be experimenting around inside of.
Oct 07, 2006 | Philips 20PT6245 TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
