Question about Master Heaters Air Hogs R/C Havoc Cyclone
My air hogs havoc cyclone stunt plane's steering doesn't work. The propeller works fine, but the rudder does not react.
  • 4 more comments
  • fsxmaster494 Jan 02, 2009
    same here
  • Anonymous Jan 17, 2009
    My rudder coil broke a wire - its a simple field that runs in one direction for right and the other for left. Unless you can find both tiny
    ends of the broken wire to reattach - no turns for you.
  • joe7390 Jan 31, 2009
    I can't see where the rudder wires route to the battery/switch/receiver area - the only thing I see is a wire(s) that *appears* to run right through the middle of the propeller shaft?!
    This can't be right.
    Joe
  • Anonymous Mar 22, 2009
    it brok right out of the box
  • Anonymous Apr 05, 2009
    After a few crashes my rudder stopped working. Any ideas?
  • Anonymous Apr 14, 2009
    i crash on to the ***** *** wall and it got fucked up radu
Try changing out the rudder or rudder may not be in neutral position.
Posted on Jan 04, 2009
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
How do you replace the propeller on the Air Hogs Sky Stunt, Blue?
To replace the Propeller on an Air Hogs Sky Stunt plane (I got this from their customer server number):
1.) Hold the propeller and turn the nose (at the grey plastic edge, not the rubber) counter clockwise (aka left) until the nose unscrews.
2.) Slid off the OLD propeller.
3.) Slid on the NEW propeller (You will notice there are slots on the propeller mount), need to line up the propeller with those slots.
4.) While holding NEW propeller, screw the nose back on (similar to step # 1) clockwise (aka right).
Hope this helps someone else.
Mar 15, 2013 | Toys
Air hogs jet set plane won't charge
This situation happened to me too after using it like 10 times it doen't
charge anymore does anyone knw what to do and what is the neutral position for the rudder how does it have to do with charging the plane I know what the rudder is and where it is ,ut don't know how to put it into neutral position.Help???
Jan 20, 2012 | Master Heaters Air Hogs Jet Set Assortment...
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
Air hog havoc goes up and down just fine, no steering control
The steering control only makes the copter rotate.
But if the heli is properly balanced a right turn should get you some forward motion. A left turn should just make it spin back to the left.
Adding weight to the front of the copter will give it continuous forward motion. Then you will lose the ability to hover.
If you visit the Air Hogs website (www.airhogs.com), select "need help" and then Havoc Heli, then crash course, the video will show you how it works.
I also find that climbing makes the heli spin left and descending makes it spin right. So full right for initial startup, then a little right when climbing, and a little left when descending helps to smooth things out.
Keep in mind that this is a very small and cheap helicopter. It took me a while to get used to flying in circles to the right but with practice I have been able to get it to go somewhat where I want it to. I can take off and land from the coffee table without crashing.
Jan 15, 2010 | Air Hogs Havoc Heli Helicopters
Air hogs havoc cyclone will not stay in the air, what can I do?
if it is a piece of hair or sting, use some snippers and tweezer.don't worry about the shaft breaking.
Jan 06, 2009 | Master Heaters Air Hogs R/C Havoc Cyclone
Wont fly
I have an Air Hogs havoc cyclone stunt plane. I am not sure if your plane has this, but on my plane's remote there left and right steering trim buttons. Play around with these until your plane flies correctly.
Dec 30, 2008 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Master Heaters Air Hogs R/C Havoc Cyclone Logo
389 people viewed this question
Top Master Heaters Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Master Heaters Toy Expert? Answer questions, earn points and help others
