Question about FIC AZ 31 Motherboard
Award BootBlock V1.0
Hi, can anyone help me this problem:
Award Bootblock V1.0
please insert bootable disket
My m/b: iwill vd 133pc
Ppi/pnp 686
Thank you
  • bigjosh1973 May 01, 2009
    My computer will ask for a floppy disk for drive A as if I were going to flash the BIOS but there is no drive A on this computer (HP Pavillion Media Center a1330n). I need to flash BIOS please help.
  • Gerhard Stoll
    Gerhard Stoll May 11, 2010
    we need the Mainboard modell Number:
    Mainboard developer is: IWill ?
    Scholar:
  • 96 Answers
Hi.
The BIOS (Basic Input output System) on your motherboard has become corrupted and the computer can't boot normally. The Bootblock is a "failsafe" device that allows the computer to boot far enough to use the floppy disk drive, even though the rest of the BIOS code is scrambled.
How do you think this happened? The most common cause is people trying to "update" the BIOS and messing up the flashing process. Sometimes some particularly nasty viruses can wreck the BIOS code as well.
Now this might be fixable. You will need to download a known good BIOS from Iwill's website and the Award BIOS flashing utility. Then you will need a bootable floppy disk (DOS) to start the computer. You will have to copy the BIOS .BIN file over to the floppy beforehand and the flashing utility. There will be information on the Iwill website on how to flash the BIOS.
Here is a full detailed webpage on how to go about all this:
http://pages.sbcglobal.net/jefn/bootblock.html
I just did a quick Google search using the motherboard details you provided and came up blank ....
If you can't get the BIOS flashed and usable again then I'm afraid it's time for a new motherboard/computer.
Posted on Dec 31, 2008
Just installed a ax4spe-n motherboard an cant get into bios. Getting error Award Bootblock V1.o Checksum error Detecting Floppy System Halted Red alert sounds have tried clearing bios then...
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password ((note you will have change your first boot device to cd))
hope this helps
Mar 28, 2011 | AOpen AX4SPE-N (91.8AT10.701) Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
I have a Award 1998 PCI/PNP 686 bios chip and need to be able to use hard drives 80 MB and over. Is it possible to replace the chip or can it be reprogrammed? I had used a Maxtor Ultra 200 V2.01 bios board...
Since Award 1998PCI/PNP 686 bios chip needs 80MB and over.. My suggestion is to buy a higher capacity drive to be able to support the boards requirements.. just post again for more questions.. thanks.. =)
Oct 08, 2009 | Intel D850MV Motherboard
Award BootBlock Bios V 1.0 (Quad BIOS)
Try to change the boot order to boot to usb or floppy and try to flash the bios.
Aug 23, 2009 | Computers & Internet
Award BootBlock Bios V 1.0 copisight (c) 2000, Award software, Inc Detecting floppy drive A media Scanning Bios image in Hard Drive..... What is this? please help me.
Hi how are u, it is simple problem friend
Your motherboard jumper setting has been changed.
please read manual of your motherboard jumper setting if u not have manual. open ur pc cover and see the motherboard jumper.
remove your bios battery and change your jumpers 2-3 by defualt.
i hope u are understand u will change your motherboard jumper settings bye.......from mukesh_ibm@yahoo.com
May 13, 2009 | Gigabyte Computers & Internet
Bios failure, or what?
Hi there.
Try clearing the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted. If there is no jumper remove the battery for an hour and make sure the power cord is removed from the back before you clear the cmos
Good luck and thanks for using Fixya!!
Feb 19, 2009 | DFI AK74-SC Motherboard
Bootblock
This messages indicates that the BIOS could not be located and loaded up. Normally this happens when the BIOS is corrupted. The corrective action required is to re-flash the BIOS using a DOS bootable diskette in the 1.44 FDD. Aside from the BIOS file, a flashing software is also needed. Pls start here.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | MSI K9VGM-V Motherboard
Please help!!!!!!!!!!!!!!!!!!
check the manual , there is a jumper plug that allows you to move a jumper over to reset the bios to default , ie , the jumper makes a connection between two pins for 10 secds and then replace back to rest position..do this with the pc off and unplugged of corse,
Aug 08, 2008 | Gigabyte GA-7N400V-L Motherboard
FIC AZ 31 Motherboard Logo
781 people viewed this question
Top FIC Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
