Question about Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television
Colours serparated, not converged, screen looks concave
Was given a Samsung HC-P4741W television but the colours are all crazy and neon and they do not match up. Looks like a psychadelic 3D show, with double and triple picture. Also the screen itself is not damaged, but there appears to be a rounded shadow at the top and bottom and sides that makes it look as though it is concave. Is there a website I can download a user manual for this television? Do these problems sound like the tv is beyond repair, or would it be worth calling a repairman?
  • Samsung Master
  • 5,138 Answers
Replace Both fo your STKs convergence ICs STK392-040s. For Parts Call 1-800-223-3205
Posted on Dec 30, 2008
DO SAMSUNG HC-P4741W TVS HAVE A TROUBLE CODE LIGHT?
if color is skewed or looks 3d its a convergence problem--select that in main menu and try to adjust--if will not adjust it needs the chips for that replaced.
Jun 07, 2012 | Samsung HC-P4741W 47" Rear Projection...
Problems aligning convergence hc-p4753 projection
Hi,if the converence is wildly pinched in say one corner compared to the other colours then it is most likely that your convergence circuits have failed for that colour. - Warning,Not an easy fix without circuit schematics and can also be costly for the IC's too
Mar 19, 2010 | Samsung Televison & Video
I have just picked up a samsung hcp4363 , used of course (for free) the colour looks 3 d but the red is out of proportion and slightly concave.
Ur convergence it dead,U must know how to solders?Tries these websites for convergence kit.Tv repair Wold.com,Tv repair kits.
Sep 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Samsung rear projection.Seems that the three colours are not aligned.There also has like a big line towards the top of the screen,which looks like a concave line.What can I do
problem with unit is convergence.you can eithor replace the board or repair it.all 3 ics should be changed-gotta also check 3.9 ohm resistors,
Sep 01, 2009 | Televison & Video
Samsung HC-P4741W has no picture and no sound
Doubt it is the convergence board. It is in shutdown mode caused by an overcurrent or overvoltage condition. It will take some troubleshooting to pinpoint the part(s) that are defective. Could also be a cracked solder joint.
Jul 06, 2009 | Samsung HC-P4741W 47" Rear Projection...
Service mode for Samsung HC-Pxx41W
with tv off,
press in sequence mute - 1 - 8 - 2 then turn on the the power
use the number keys, the direction pad, volume and channel buttons to adjust convergence
Mar 19, 2009 | Samsung HC-P4741W 47" Rear Projection...
Bad color scheme - cannot adjust enough
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
Feb 25, 2009 | Samsung HC-P4741W 47" Rear Projection...
Greenish haze on my Samsung HC P4741W
If you purchased it new then this clearly should not happen - if it is second hand and therefore older then the red tube could be burnt out. The convergance may simply require allignment if the set has been knocked about trying to get it to its final resting place - this would need a tech on site to set it up.
Feb 14, 2009 | Samsung HC-P4741W 47" Rear Projection...
Samsung hc-p4741w flashing red light
That sound is made by the power supply who's gooing in protection mode due to some overcurent in secondary. Could be many reasons: conv. amp. IC's, video amp.IC's etc. In my opinion more then 70% chances to be the STK for convergence. Need to be troubleshooted by a tech.
Dec 07, 2007 | Samsung HC-P4741W 47" Rear Projection...
Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television Logo
264 people viewed this question
Henry  Thomas
Henry Thomas
