Question about Pyle PLTS76U Car DVD Player
Pyle override park brake code
Is there a code for the Pyle PLTS76U car dvd player to override the parl brake in order to watch movies while driving?
  • Anonymous Mar 14, 2014
    where is the eject button on the pyle car dvd player PLRD153IF
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Posted on Feb 12, 2009
    New Friend:
  • 3 Answers
Pyle pldn74bti bypass codes w/no switch parking brake
Posted on Dec 30, 2012
Ese es el cable q hace prender el resto de las luces de la caratula
Posted on Apr 21, 2010
I could be sitting right in my driveway and i put in a DVD, how come it keep saying can not function this while driving??
The reason why is because the receiver is not registering that you have a constant ground connected to the parking brake. Depending on the model, you should be able to hook the wire that tells you parking brake up to the ground wire of the receiver. If that doesn't work, then you are going to need to use a switch that is hooked up directly to ground. Based on the last Pyle receiver I saw, you should be able to do the parking brake wire to ground and be fine.
May 19, 2010 | Pyle PLTS76U Car DVD Player
Tip
How to watch pyle plts76u car dvd whilst driving and how to bypass parking brake...
If you want to use your dvd player whilst driving then i will tell you the best way to go about doing this but please read these warnings first.
WARNINGS.
1. any work you do at your own risk
2. it highly illegal to use any dvd or telly whilst driving
3. if caught using dvd whilst driving you will get a big fine and points on your license for driving whilst distracted.
4. if you have an accident whilst the dvd player is driving you wont be insured and you will be liable and charged with dangerous and reckless driving.
5. any short due to work carried out can cause you to destroy the stereo and in some cases cars have been set on fire, so if you are unsure what you are doing then please dont go ahead with this work as you could end up in a right mess.
Ok now the warnings are out of the way.
I take it you dont want to watch the dvd whilst driving but a passenger does i dont reccomend this work be carried out if the driver is planning on watching the dvd whilst driving, its not worth the risk its just to dangerous.
How To Bypass The Parking Brake To Watch DVDs'
the best way of doing this would be to get hold of the instruction manual to install this stereo you might get this off the net but if not you can contact the makers and they will be able to send you one for free, just the cost of postage to pay.
Now to actually bypass the parking brake witch dont let you play dvd whilst driving what you need to do is locate the wire that goes to the parking brake now this wire should be a brown wire unless somebody has re wired the stereo to fit other cars, once you are sure you have located the correct parking wire thats brown you then need to remove this wire from the parking brake. Now you need to earth this wire out to any metal on the car and secure it to that metal part this should then bypass the parking brake system for you.
You do this at your own risk you can destroy the stereo and in some cases set fire to the car so if you have never done this type of work before then please leave this to somebody who knows what they are doing.
Take your time, make sure you have the correct earth wire any other wire and you will short the stereo out destroying the stereo and possibly your car, so be warned.
on Mar 03, 2010 | Car Audio & Video
Pyle plts76u shows split screens how can i solve thi roblem
I wired my parking bake(brown wire) to the ground wire(black wire), and it allowed me to drive with the screem up
Mar 15, 2009 | Pyle PLTS76U Car DVD Player
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
How to drive with dvd playing PLTS76U
eASY... CONNECT THE BROWN BRAKE WIRE TO ANY GROUND IN THE VEHICLE....
Feb 12, 2009 | Pyle PLTS76U Car DVD Player
I doesn't work
gound pink wire in order to make video play
How to watch a video while not in park
1, Insert DVD. Activate Brake.
2. Next, on the main remote press stop twice, then 1,2,6,4.
3.You will see a hidden menu that says:
Region Code
Brake Override
Macrovision
Loader Version
Model Version
4. Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
5. This is what you want:
Region Code: 1
Brake Override ON
Macrovision OFF
6.When your done, click SYS SETUP on the main remote TWICE to save the settings and Bingo, You're done.
Mar 27, 2008 | Jensen VM9510 Car DVD Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Pyle PLTS76U Car DVD Player Logo
1,107 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
