Question about Konica Revio KD-100 Digital Camera
Menu in Chinese
I have turned on my daughter's camera and everything is in Chinese. As I can't read the menus to find how to change it, cam anybody help. Let's assume, for arguments sake, I am a complete novice. Thanking you in anticipation.
0 characters
1 Points
Sony 12 megapixels 2.7"TFT 8*zoom anti shake. I have accidentally chosen chinese on the camera and I don't how to get the camera to read in english.Everything on the screen is now in Chinese
You did not say what the model is.
Download manual from web and find out how to change to English or find someone that speaks Chinese and ask them.
Aug 14, 2013 | Sony Digital Cameras
Some one has given me this camera which was purchased from china. all the icons and menus are in to change them to english
??(settings)-> ?? (menu)-> ??(language)-> ??(English) If here can't show the words in Chinese I have type you can translate the words to Chinese here
Aug 15, 2011 | Sony Cyber-Shot DSC-W530 Digital Camera
We cannot zoom in or out on the lense and the have to focus manually , this occured after our 9 year old daughter used the camera, did she just switch some sort of adjustment that locked everything up??
What you can try is this. Turn the camera off. Remove the lens.
Put the lens back on, turn on the camera. note any messages.
You should read your manual.
You may be set in manual mode on the camera or the lens or check both.
Make sure that the camera is set to auto lens in menus and on the camera, if it has a setting on the outside.
Make sure, if the lens is AUTO, to set the switch to auto.
Hope it works.
Jul 10, 2011 | Canon EOS Rebel XSi Digital Camera
I need to change the menu language to English, as it turned to Chinese by mistake. Please help me. Thanks, El-sayed
Hello, That's the same camera I have! I can help you. Follow this sequence to reset all the settings so that the language becomes English:
  1. Turn cam on
  2. Press the "menu" button.
  3. Press right directional key (marked with the flash symbol)
  4. Press down directional key to go to the bottommost entry of the menu (which is the reset all option)
  5. Press the "set" key (in the middle of the directional keys)
  6. Press the up directional key and then "set" to confirm.
There. you're done. Now you don't have to learn Chinese to use your cam!
EXTRA NOTE: BTW just in case this applies to you too; When I first got my cam, I had trouble finding the timer option to time the shutter (1-2-3 click!) It's called "drive mode" in this camera.
May 07, 2011 | BenQ DC C1030 Eco Digital Camera
How do i change the language to english on my vivi cam x327 , i turned it on and i think its chinese . . ?
Press the MENU button. Use left/right to select the wrench to bring up the setup menu. Use up/down to select the tenth item.
Dec 28, 2010 | Vivitar ViviCam X327 Digital Camera
I have just bought a fuji z35 camera and when I switched it on for the first time it has come on in chinese, and I can't understand the menus to change it back to english please help
Unless you have a friend who can read Chinese, you will need to go into the menu and go through each menu and sub-menu until you come across the word "english" at which point you would press the select/ok button.
Nov 17, 2010 | Fuji Digital Cameras
My camera language was changed to Chinese..I
You will need to go into the menu and painstakingly go through every menu and submenu until you spot the word "english" it and click on it.
Mar 14, 2010 | DXG Technology DXG-552 Digital Camera
How to change the language setting on my Canon SD750?
1. Turn the camera on, make sure it is in playback mode.
2. Press and hold the Func/Set button, and while still holding
3. Press the Menu button. Release both buttons.
4. Use the arrow keys to highlight desired language
5. Press the Func/Set button
Dec 09, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Changing the language
The CG6 manual states how to find the change language option in the menus on page 135. Even though you can't read the characters, the position on the menus should be the same.
Dec 23, 2007 | Sanyo VPC-CG6 Digital Camera
From chinese to english
Right from Cannon:
How do I set the language?
Solution: Procedure for setting the language PowerShot S5 IS.
Setting the Language
The language in which menus and messages are displayed can be selected with this function.
Method 1
  1. Power the camera on in the playbackicon.gif (Playback) mode.
  2. Hold down the <SET> button and at the same time press the <MENU> button.
  3. Use the direction_arrow_up.gif, direction_arrow_down.gif, direction_arrow_lt.gif, or direction_arrow_rt.gif button to select a language and press the <SET> button.
Method 2
  1. In the playbackicon.gif (Playback) mode press the <ON/OFF> button until the power lamp lights.
  2. Press the <MENU.> button to display the Rec. or Play menu.
    - Use the 023.gifbutton to select the setup_icon.gif(Set up) menu.
    - Use the 021.gifor 026.gif button to select LANGUAGE and press the <SET> button.
  3. Use the 021.gif , 026.gif, 023.gifor 028.gifbutton to select a language.
  4. Press the <SET> button.
  5. Press the <MENU> button to redisplay the Rec. or Play screen.
Oct 12, 2007 | Canon PowerShot S5 IS Digital Camera
Konica Revio KD-100 Digital Camera Logo
Top Konica Digital Cameras Experts
Lawrence Oravetz
Are you a Konica Digital Camera Expert? Answer questions, earn points and help others
