Question about XM Radio Dual XMP7000 Auto In-Dash CD player and XM Satellite Radio
XM Roady is non functional
I have a XM Roady XT. XM has sent a reloading signal three times but it shows loading all day long. As I scanned the channels it showed the same names of the songs several days in a row. I bought a new antenna in case that was the cause but no improvement. I really do not want to replace it and my docking stations. Can you fix it? Craig
    New Friend:
  • 57 Answers
Turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
Posted on Jan 10, 2009
I have enjoyed my radio for about 2 years. For about two weeks I get the message"loading" on my radio. It does not happen all the time, but it seems like it is happening more frequently. It will...
Just a few weeks ago Sirius XM changed there channels. That might have been one problem. But it shouldn't be loading all the time. It might be losing the channels and have to reload the channels.
May 26, 2011 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Jun 01, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Can't get Roady XT to turn on. Previously wouldn't load signal.
there is a bad connection on the voltage input on the radio. look in the hole you will see a copper contact if it wore, you will see a hole in it, you needed to bend it towards the center contact just a little bit. then try it again I worked on mine
Dec 26, 2008 | Delphi Roady XT XM Radio Receiver
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Jan 24, 2008 | Delphi Roady XT XM Radio Receiver
BelkBF5X007in XM radio boom box
Check your Conns both on Radio and docking Bay make sure Nothing Got on them .Clean them with alchol and Swab Good luck ttech
Jul 20, 2007 | Belkin F5X007 XM Radio Receiver
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Jun 18, 2007 | Delphi Roady XT XM Radio Receiver
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Car Audio & Video Logo
235 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
John
John
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
