Question about RCA D52W19 52" Rear Projection Television
Set want start up
I have a D52W19BYX1 about 4 years old, it started rolling red bars from bottom to top, then the set was hard to turn on, had to click the power button several times to get on, now set want turn on.Is it worth getting fixed?
  • RCA Master
  • 5,138 Answers
On Deflection board the one that has FBT on it CK cp150 2200uf 16v capacitor look to see if it is puffed up ontop if so it is bad so replace 2 more caps cp114 cp120 220uf 35v.you can buy capacitors at Radio Shack.
Posted on Dec 30, 2008
How do you disassemble the pool and filter
  • gets lots of people
  • host a barbecue
  • and start dis-assembly
Of course, empty the pool first!
  • Then begin by removing the top rail
    • Screws will be on the piece over the joining rails.
  • then remove the ridgidizing bars
  • then remove the plastic coping strips
  • then lift off the liner off of the wall
    • Lay it into the pool
    • fold it, nicely into a square
  • locate the bolts & nuts that join the wall
    • remove them
    • then start rolling into a roll
This is where the multitudes of people come in, during the time the ridgidizing pieces were removed, the wall is very unstable & very wobbly!!!! People need to hold it from falling over and bending the wall. Once the wall is no longer attached in an oval or circle, and started to be rolled into a roll, you will need to have the people work as a team and lift out of the bottom ridgidizing pieces and stabilize the process of rolling the wall.
Once the wall is rolled up, gather up the bottom rails and the foot pads.
Good Luck.
Sep 17, 2014 | POLYGROUP LIMITED Summer Escapes - 24x52"...
Have red vertical lines in center of screen from top to bottom
iam also facing same problum,that problum wont start immedietly,when we r watching after 1 hr it will start
Oct 21, 2012 | Hitachi 42HDS69 42 in. Plasma Television
I have a problem with my Sony Bravia. The screen is cut in half with a fine black line. The top section is the picture that continuely rolls and bottom section is lines of colors. It is 9 months old.
Depending where you got it It's probably still under warranty.I know Bestbuy usually offers 1 year free.My tv had red lines running through it and they said it was something to do with a climate part that they did not have so I was sent to pick out a new Tv.Good luck
Jan 12, 2010 | Sony BRAVIA KDL-46V3000 Television
My TX is about 14 year old. The picture alwasy was excellent until we had an exlectrical storm that knocked out the cable box to the TV. With a new cable box the TV works. The picture has excellent color,...
Try your cable box on a different tv set and also try connecting the cable directly into the t.v, if that makes no difference then your tv set may have a power supply problem that was caused by an a.c line surge during that storm.
Oct 31, 2009 | RCA F19253BC TV
Rolling green horizontal bar from top to bottom,then bottom to top and so on. sometimes rolling fast,sometimes slow and sometimes the green bar stops in the middle of the screen.every once in a while the...
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
Oct 25, 2009 | Mitsubishi WS-48513 48" Rear Projection...
How do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Apr 21, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Red bar across the top.
First things first. If you took the lamp out of the chamber, make sure the lamp is back in place correctly. You may have to "snuggle" it up a little with your fingers (not too hard, just make sure it is in the chamber properly). Then put the door back on properly, which can be a hard thing to make sure of on this set. If you feel any resistance, it is not on right. It should go in and fit just right. Lock it down with the bar, and try the power.
The red stripe across the top is something I'm seeing more and more of these days. The optical block on this television is showing some of the same symptoms that the older ones have been showing for years. They go bad.
I'd call Sony (you can look up the number on the sony website for customer service). Ask them if there is anything they can do to help you, because the optical block is quite expensive.
I hope this helps you...
Jan 08, 2009 | Sony KDF46E2000 46" Projection HDTV
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Red tint on the entire picture
Always try your extended warranty!.....Probable cause = bad
red tube. One adjustment may help---turn down red screen
control, located behind technician access panel in front of set.
Nov 04, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Picture has rolled up leaving a black bar on the bottom
Greeeting from Belize you are having a problem either with cold solder or a problem in the power supply those lines are hum bars due to a defected filter cap.resolder your power supply if that does not solve the problem then you replace the power supply you can get a power supply kit from www.dalbani.com in florida.good luck.also make check in the vertical section if you cannot do it your self take it to a qualified tech to resolve your problem this should cost you about $75.00. to get it fix.
Oct 30, 2006 | Samsung DynaFlat TX-P3076WH 30" TV
RCA D52W19 52" Rear Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
