Question about Dualit 20247 2-Slice Toaster
Problems with Dualit 20247 2-Slice Toaster one of the elements is out. Both sides of one toast is good, the other heats up only one side, as the element on the right is dead. Where can i send this, as i like the toaster. Need it to work more than 3 years. Jouko J. Rissanen Bought it at Wm Sanoma
  • 979 Answers
It is probably not under warranty. I would advise getting a new one. By the time you send it off and pay the repair and get it back, you will have a repaired toaster will a question mark on when it will go down again. Get a new one same brand.
Posted on Feb 07, 2009
My dualit toaster heats up but the element doesnt go red do i need a new element
Yes only the ones that not getting red, there are in ebay, very good price and they wll arive to you in days.
You can find istruction how to order and how to replace in this tip
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Aug 28, 2010 | Dualit 20247 2-Slice Toaster
Dualit toaster
You van by the elements fromebay uk they are so slim and light that they shipp them in normal envelope and arive in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
Good luck
May 30, 2010 | Dualit 20247 2-Slice Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Dualit Toaster won't heat on either side.
You may have awire that has burned off or the control switch is bad. You can get to their site by typing in "dualit" under google and you will get a lot of information and the web site.
Feb 06, 2009 | Dualit 20247 2-Slice Toaster
Dualit 20247 2-slice toaster
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This is operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Jun 25, 2008 | Dualit 20247 2-Slice Toaster
Dualit 2 slice toaster
The top red button is the heating element selector.
If you push it to the left, only the left side is going to turn on.
Push it to the right and both of the heating elements will turn on.
Idea behind this comes from the commercial background where you save electricity on using only the elements that you need.
the bottom is simply a timer.
you can get an instruction manuat at:
www.dualitusa.com or email your request to:
irene@smithagy.net
Jun 19, 2008 | Dualit 20247 2-Slice Toaster
DUALIT 2 slice toaster
The Dualit Repair Center is:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Apr 08, 2008 | Dualit 20247 2-Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Replacing the elements on a Dualit 2-slice
You can find out how to replace the heat elements and purchase replacements at the Dualit Repair Center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 05, 2007 | Dualit 20247 2-Slice Toaster
Dualit 20247 2-Slice Toaster Logo
354 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
