Kalorik WCL-20629 18 Bottle Dual Zone Wine Cooler Logo
Mike Posted on Oct 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot locate any info re how to repair, doesn't appear to be accessible
Anonymous
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Oct 31, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
42
Questions
49
Helped
11952
Points
117
I found a manual for you! visit http://kitchen.manualsonline.com/manuals/mfg/kalorik/usk_wcl_20629.html and click on Get This Manual, good luck.
Subaru Tribeca: Front screen washer doesn't work
AutoZone has free repair manuals online. Should be able to find fuse locations.
Horn & Cruise control doesn't work
The clock spring has gone bad. You will have to remove the steering wheel to gain access to the clock spring (used to be called the turn sig. switch) But if you are going to perform this repair make sure you dis-connect the battery before you began because you could set off the air bag in the steering wheel
P1320 on a nissan xtrail 2002 model
That is a Manufacture Code we don't have
Don't know who clears the check lamp, but
that doesn't do any thing other than remove
the codes needed for a repair shop to find &
resolve the problems
Cruzer flashdrive light doesn't light up
Use this USB drive on another working computer to check if your OS has any problem or not. If the drive is detected and you can access the infos stored in this drive, repair your OS, and if not, go to your nearest service center to avail a full replacement or repair.
Hope this helps, Mrityunjay.
Interior fan want work
First, check the fuse block for an open / blown fuse. You didn't provide the make & model of your car, so you'll have to find out which fuse is used for the fan. Replace any open / blown fuse found with the correct size as determined by the manual. If it still doesn't work, keep reading:
Many cars and trucks use what is called a "resistor pack" that is used to determine various preset speeds for the heater & A/C blower or fan. When you switch the fan from one speed or another, power is passed through a different value of the resistor - which changes the voltage to the fan motor. The different voltages provides different speeds.
The resistor pack is usually the problem if the fan works at one or more - but not all speeds. It can be the problem if the fan doesn't work at all either. The location of the resistor pack varies with vehicle make and model, but is often very close to the motor itself and accessible from the passenger compartment. Consulting with a employee at an auto parts store or Chilton's (or similar) auto repair manual should get you to the right spot. Resistor packs are relatively inexpensive at about $25 or less.
I hope this helps & good luck!
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Top Kalorik Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kalorik Furniture Expert? Answer questions, earn points and help others
