Question about Logitech MOMO Racing Force Feedback Wheel
Driving wheel trying gtr2 with driving wheel.all is good exept that the wheel is too sensitive. steers left or right but not strait. HELP
In the logitech software under steering wheel axis properties in an option called deadzone. increase this slightly. 5% works for me.
Posted on Aug 31, 2009
How to fix Hyundai Accent 2005 steering wheel?
HIMA you have a bent tie-rod or broken not safe to drive until you have this problem checked out quickly! TAKE IT TO HYUNDAI DEALER FOR HELP!!
Jan 25, 2016 | 2005 Hyundai Accent GT
Lumina troubleshooting
first check the condition and level of p/s fluid. if low top off first and turn your steering wheel left to right and back several times to try to bleed air out of p/s system. if p/s is still stiff or hard your p/s pump pressure output can be measured with a pressure gauge. if pressure is below specs its time to replace it. if your p/s output pressure is good then you would need to inspect your p/s hose or lines for kinks or restrictions to your steering rack. on certain model vehicles p/s sensitivity can be adjusted on the steering rack. you would need to check the vehicles service manual to see if its possible to adjust steering rack sensitivity.
Aug 29, 2014 | Chevrolet Lumina Cars & Trucks
Why ignition won't turn
By far the most likely reason that one can't turn the key in the ignition is because the car was parked with the wheels turned. There is a security feature that locks the steering when the key is removed to prevent a thief from driving the car.
When the car is parked with the front wheels other than strait, the weight of the car will cause the wheels to try to straiten, If this engages the steering lock pressure is put on the ignition switch.
To start the car, look to see what direction the wheels are pointing. grasp the steering wheel and turn it TOWARD the direction the wheels are turning and now start the car.
Other causes may include wrong key, damaged ignition or other causes that may require a professional.
Aug 16, 2014 | 2009 Nissan Versa
My 2000 jetta pulls to the right under hard acceleration but drive strait at speed
If it is PULLING to the right, is it STEERING or TORQUE that is pulling it?
What I mean is this... If ONLY your Right Front Wheel is pulling with the Acceleration and the LEFT is not,m you will have a Torque Pull,
You may have a problem with your
a. Left CV Axle
b. Transaxle Internal Failure
Apr 06, 2013 | Cars & Trucks
When driving 40mph let go of steering wheel car pulls to the left ,2002 toyota avalon
Try flipping the front tires right to left and so on car may have a radial pull road test to see if it goes right or strait (first check tire pressure )
Jan 16, 2013 | 2002 Toyota Avalon
I hear a loud grinding noise when i drive my car
Check front tyres & wheel bearings espesially the R/H/F. Feel tyre for high / low spots on inside & jack up & spin wheel if you get noise while jacked up it is not the tyres but wheel bearing or brake pads but more than likly a crook bearing by the sound of it. It needs to be tended to ASAP
Jun 28, 2012 | 2004 Volkswagen Passat
My steering wheel turns more to the left than to the right. it also does not spring back like it does when i turn to the right.can somebody help?
is it power steering could be fault in system if it is not then could be suspension ange problem the steering rods should be set so the wheels are set strait ahead the steering wheel with the ball joints disconnected should be tuned full left count turns on weel then full right set in the middle and adjust ball joint rod lengths and reconnect also check stops at rear of hub
Jan 28, 2012 | 2004 Toyota Corolla
2005 dodge ram 1500, drove down the road to my moms ans then got back in to leave. the ignition would not even turn
If the key won't turn, try to move the steering wheel left or right, the steering/ ignition lock plate can hang up if the wheels are not strait
Jan 06, 2011 | 2005 Dodge Ram 1500
I have a 2004 Dodge Intrepid 2.7L SE. As I was pulling out to make a 3 point turn (turning left) my car was hit. When it hit, it pushed my tires strait but the steering wheel stayed left. So now when I...
Fixed Properly: You need to bring it to a shop- Modica Bros/Pep Boys/Firestone/Disount Tire/Etc. It's a simple alignment and it'll cost somewhere in the $120 price range - possibly less.
Sep 30, 2010 | 2004 Dodge Intrepid
Steering jumps left or right while driving. WHeels and tires are ok. I hear there are problems with the steering pump wiring.
You need to have your speed sensitive steering sensor checked out. What is happening is that a relay adjusts your steering based on the spped you are going. I have has the same problem, and it wasn't noticable at low speeds, but as you increased speed, it would cause the vehicle to jump left or right, as if you were intentionally swerving a pothole. Have a good mechanic look at it and it shouldn't be to costly. Good Luck.22
Jun 24, 2009 | 2003 Mini Cooper
Logitech MOMO Racing Force Feedback Wheel Logo
308 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
