Question about Denon AVR-2807 Receiver
Display on Denon AVR-2307 won't work
Display on Denon AVR-2307 will not show up. Have tried everything.
  • Anonymous Jan 25, 2009
    had the same problem - sent the unit back to Denon under 2 year warranty.They rang me to say that the display looked OK and no apparent fault.Still don't know what went wrong but, like you, I had tried everything.
  • 163 Answers
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
  • 4 Answers
It may seem obvious, but have you checked the display dimmer settings? Under the front cover is a button marked dimmer. Pressing it cycles through progressive display dimness settings until it goes off. One more press goes back to full brightness.
Posted on Jan 10, 2009
Denon AVR 789 no display
Time to send back to Denon (seriously). Hopefully you have a warranty on your product (I bought mine at Fry's and it took a few months for the warranty work to be performed). Good luck!
Jan 15, 2012 | Denon AVR-789 Receiver
My Denon avr-2307 have a dead LCD display
If you can solder, you may be able to fix this. Many of these that I have seen have poor solder connections at the display itself. Carefully open up the unit and locate the rear of the LCD panel. There should be a long line of connections. Check the ones on either end. These are the supply and ground connections. Quite often these connections crystalize and break. Resolder them and try the unit again.
Let us know if that resolves the problem.
Thanks,
Dan
Sep 14, 2009 | Denon AVR-2307Ci Receiver
Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Aug 23, 2009 | Denon AVR-2307 Receiver
Picture takes 1 min to show up on TV thru HDMI
There are firmware upgrades on (some) receivers, call customer support for Denon, or an authorized service center. They can help you over the phone. If you need more help, post a comment and I can help you further.
Aug 05, 2009 | Denon AVR-2307 Receiver
NO GUI displayed
I had a similar problem with my Denon 3808 after it had the protection circuit tripped. First all I would get is a blue screen with sound, then after powering the unit off I got the display back, but all of the on screen GUI menus were gone. I could tell that the menu button worked because display located physically on the recever worked. I reset/rebooted the system (follow the directions in manual) and everything came back. Be aware by resetting the system any customization you have done will be lost. Hope that helps
May 30, 2009 | Denon AVR 3808Ci Receiver
DENON 2308
IF YOU HAVE A MANUAL FOR YOUR DENON THE INSTRUCTIONS FOR ADJUSTING THE BASS AND TREBLE IS ON PAGE 40 UNDER TONE CONTROL IF NO MANUAL FOLLOW THIS LINK TO DENONS WEBSITE http://www.usa.denon.com/AVR-2308CI-OM-E_109.pdf
Nov 26, 2008 | Denon AVR-2307 Receiver
Denon AVR-3802 Front Display problem
This can be either the display itself or the display driver IC havng problems. Something as simple as poor solder connections may cause this as well. Without seeing hte unit, it is difficult to say what the real problem is. If you can solder, try resoldering all of the voltage regulator ICs in the unit. These look like transistors and will be marked 7805 or 7812. If the voltages drift too low because of bad connections, the ICs can get "confused" and not work properly.
Keep us posted.
Dan
Aug 26, 2008 | Denon AVR-3802 Receiver
DOG!!!!
I'd look here first: http://usa.denon.com/ServiceCenterLocator.asp
Dec 18, 2007 | Denon AVR-2307Ci Receiver
Denon AVR-2807 Receiver Logo
798 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
