Question about Panasonic PT-47WX49 47" Rear Projection Television
Convergence problem re: Panasonic PT-47WX49 rear-projection HD television. Hello. Turned on TV tonight and the blue projector was way out of whack. Happened suddenly. I am familiar with the convergence controls and tried to realign everything, but could not "move" the blue to line up. Any help would be appreciated. Thank you.
If you cross reference this term, I think you'll find alot of helpful info on your problem:
Convergence amp ICs
These (there are probably two of them) are probably burned out, at least one of them. From what I see online in blogs and such, this repair can run several hundred dollars to have done professionally, but if you are qualified (or at least careful enough to learn how to do it SAFELY and CORRECTLY) you can do it youself for around $12 - $50, depending on what model part your set uses.
Hope this helps. I am about to embark on this same repair myself on my Panasonic PT47WX53G, so my best to you.
Posted on Dec 31, 2008
I have a panasonic projection tv from 2001 the blue projector is ofset and the remote will only alter the projection up and down not left and right. This is causing a double imageof a blue outline
Very common problem caused by failed convergence IC. You can get the panasonic convergence repair kit for your model from www.tvrepairworld.com which has the ICs, resistors and the CD with repair instructions.
Mar 20, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Feb 14, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Blue and yellow shadows on TV
dear friend,
the problem of your tv is a burnt image!
solution: replace blue crt
Jan 20, 2008 | Panasonic PT-47WX49 47" Rear Projection...
White outlines in HD mode
is the screen control turned up to high if so you would see white lines on a dark picture
Oct 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47wx49 47in
One of the resistors in the circuit connected to one of the ic's has burned out or changed value due to heat caused by short in previous ic before it was changed.
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic rear projection TV 47 in PT 47WX49
Camaroguy: This exact problem happened to us about 8 months ago. A board had to be replaced at a cost of $500. Yesterday, the convergence has gone on the set. You get a blue and yellow shadow on the picture. From what I have been reading, this has happened on a few TVs and it will cost another $500 or so. We refuse to pour more money down the drain so we just went out and bought a new plasma (RCA) for half what it cost us for the Panasonic 4 years ago. We have never had a problem with RCA in the past (two tvs for 20 years a piece).
Mar 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 Convergence IC
usjavelin. I have the pdf files for the tv. I own the same one. I can send them to you if you'd like.
Dec 16, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
