Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Given sansa c250  mp3 player as gift , i have mac osx computer  un successful with down loading songs .when i plug cable in and search for songs on list they are there ,but when i unplug cord and check for the music on the mp3 player there shows there is no music.I am quite new to the computer scene so please explain quite plainly as im not all that familiar with all that technical jargon .i hope you can help
  • 8,596 Answers
The songs that you are trying to transfer must be in mp3 format.
Posted on Dec 30, 2008
Why do the songs on my MP3 player not show up on my computer?
format it .and update it firmware
(download firmware from sandisk, site ) ite to easy
Jul 19, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk MP3 Player c250 2 gb
You have to make sure the USB Mode is in MSC for it to have a prayer of working, but generally this player is not really Mac compatible - manual aside
-Tha Mp3 Doctor
Jan 09, 2009 | SanDisk Sansa e250 MP3 Player
Successfully downloading music onto Sansa c250
Here is a link to the manual:
http://www.sandisk.com/Assets/File/Downloads/user-guides/c200-ug-eng.pdf
If you are certain that all of the files are in mp3 format, then your best bet would be to change the USB Mode of the player - if it is in MSC Mode, chnge it to MTP Mode and vice versa - instructions for doing this are in the manual.
-Tha Mp3 Doctor
Dec 31, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Synchronize songs to Sansa c250
newtech -change the USB mode on the player away from where it is now. Turn on then press and hold the rewind button while plugging to the PC.
darama - you have to plug the mp3 player into the computer and refresh it through Bearshare. If you let your subscription lapse, you won't be able to use the songs naymore.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Help
software for the sansa c250 on my computer
Sep 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computer doesn't recognize MP3 player -
I think I have a solution. First you turn on the MP3 Player and then go to the menu. Go down to settings. Then, go to USB. Go down to "MSC" and hit the middle button. It should take you back to the settings menu. That means you successfully changed that setting. Now plug the MP3 Player back into the computer and open up "My Computer." It should show up. I hope this helps!
Jul 24, 2008 | SanDisk Sansa m240 MP3 Player
Not charging.
Probably hardware and needs to be replaced, but:
-Tha Mp3 Doctor
Jul 24, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Removing songs from sansa e250
Try To Format The Player, Sorry I dont have Mac
Jun 15, 2008 | SanDisk Sansa e250 MP3 Player
Can't load songs
ive had this same problemo. you cant use the media converter to drag and drop songs. you have to download your songs or rip them onto windows media player. you plug in the sansa and then when its recognized there will be an area on the right hand side where you drag the songs and they appear on sansa.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
