Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
My external hard drive is unreadable
My hard drive is unreadable ? I purchased a 1TB Seagate Freeagent and knocked it over, dislodging the usb port from the drive. I purchased a Rosewill hard drive enclose and installed the HD from the Seagate into it.
The 'device manager' program that came with the Seagate flashed 'no drive connected' when I plugged in the USB cable. About 10 minutes later my computer recognized the HD, the usb with green check icon appeared and windows searched for drivers. The drivers were installed and the HD now appears in my device manager.
Device properties show the HD as ST310003 40AS USB Device.
Device type: Disk drives
Manufacturer: (Standard disc drives)
device status: The device is working properly
When I click the Volumes tab, it shows no Disk, Type, Status, Partition Style, Capacity, or anything.
Updating the driver doesn't work. Computer > Manage > Disc Management shows my regular hard drive as Disc 0, and my External as disc 2, but says it's 'unknown' and 'unreadable.'
The properties there show
Disc: Disc 1
Type: Unknown
Status: Unreadable
Partition Style: Not Applicable
Capacity: O MB
Unallocated space: 0 MB
Reserved space: 0 MB
Is there anything I can try to get my computer to recognize the drive?Otherwise I will have to return the external case! I have 400GB of important files, but won't pay for software or data recovery.
Thanks!
Alex
  • 1 more comment
  • mouraalexand Dec 30, 2008
    Thanks for the response zzptichka,
    I couldn't listen to those sounds but the HD is making a strange noise. Every 3 seconds it makes a faint buzzing sound.
    When the noise stopped, the computer recognized the HD, but I still can't get it to show up as the F: drive as it used to be. I doubt it's the enclosure either.
  • Bionicbrain Jan 11, 2009
    I have the same problem as above but i have only used the hard drive 12 times since I got it for my birthday. The light indicates that the hard drive is sleeping about 1 minute after the device is plugged in. My machine makes a noise similar to a cd spinning that goes for about 3sec, at 5 sec intervals. None of the sounds on this site sound like my machine.
    My life is one this hard drive, as is several episodes of True Blood I am yet to watch! Oh the pain of it all...
  • 95 Answers
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
Unexpected turn off
Can you navigate to the external drive via Windows Explorer?
Did you try restarting your computer? Unplug the external completely, then reconnect it?
Oct 21, 2013 | Seagate FreeAgent Pro 1TB External USB...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Can external hard drives be "piggy backed"? I have
Each external device connects to one USB port on your computer.
So, you'll have no problems running two devices at the same time, in different USB ports.
Dec 13, 2010 | Seagate FreeAgent Pro 1TB External USB...
I have a seagate 1tb external hard drive. i knock it off my table and it landed cables down. Unfortunatly it push the usb connection in the hard drive in and it cam apart. I opened up the drive and it...
You can try soldering it back, but it may still not work. If your soldering skills are not great, you should probably let someone who does that kind of work for a living try the repairs. Give me a call if you need to.
Jan 07, 2010 | Seagate FreeAgent Pro 1TB External USB...
I have just purchased a Seagate Freeagent 1tb drive and
Yes to all. First, You can share them by setting it as a network, or shared drive. Right click the drive, and choose sharing and security. Set the share name, and then connect it to the other computers by pointing them to this address: \\COMPUTER-IP\SHARE-NAME
Second, the manual should be in the drive when you first got it, but if it got deleted, the only way to get it again, would be to borrow another drive, as it comes with a custom key to extend the software trial to 100 years, and therefore is not hosted online.
Last, You can partition it for free with EASEUS partition manager home. You can get it here: http://www.partition-tool.com/personal.htm
I hope I helped.
Jan 02, 2010 | Seagate FreeAgent Pro 1TB External USB...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Folder unreadable and corrupted. files lost.
hey down load PCI recovery for recovery of files
May 25, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Hard Drive Buzzing and Wont work (Seagate External Freeagent 1TB)
You are in trouble!
The buzzing sound is the heads trying to realign themselves at the beginning of the platter.
You could try putting it on a side and hope gravity helps.
But i'm afraid its broke beyond repair.
May 13, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
2,200 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
