Question about Philips MX3700D Digital Surround Sound Receiver System System
Only 2 of my 5 speakers are working
I have a philips 5.1 sound system (spa2600) and only 2 of my 5 speakers are working and i tried to put the speaker which wasn't working in to another port and it worked so theres no problem with the speaker and i have no idea what could be the problem...tks for helping
  • 8,596 Answers
Press the SURR button until you get sound on all five speakers. If you don't get sound on all 5, there are a few possibilities:
1) the program you are watching only gets stereo sound or lower (only two or one speaker will play in this case)
2) you need to get a digital audio cable instead of using the red/white AV cable
3) a setting on the TV, cable, or satellite box needs to be changed to allow surround sound in full
Posted on Feb 19, 2008
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
Computer will not recognize Philips Portable Speaker System SBP1150.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 28, 2010 | Philips SBP1100/37 Portable Speaker System...
My Philips HTS3566D home theater stereo system speakers do not work. Sound comes from the tv, but not from the speakers that came with the Philips unit. I've tried different modes (party, dolby, etc.)...
I have the same problem. The front right and left chanels are fucked up while the center and rear right and left are working normally. I can't imagine what's the problem.
Sep 04, 2010 | Philips HTS3566D/37 Theater System
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
I have no sound :(
If the (internal) radio doesn't produce sound it's not signal cables. What cables were you exchanging?
This sounds like a basic NO SOUND problem.
How does it fare when you run speaker setup?
How about the MUTE button?????
Jun 05, 2010 | Philips HTS3544/37 Theater System
Philips lx3000d surround sound system. centre
cross check the audio device settings. check the audio level of each channels.
Also try exchanging the speakers whether the speaker itself is damaged.
Hope this helped.
Jan 05, 2010 | Philips LX3000D System
Problem with rear speakers
hello
can sell me the junction box?
thanks
contact brilhasman@clix.pt
urgent
Jun 01, 2009 | Philips Cineos HTS9800W System
Not getting full 5.1 sound from PC to surround sound system
well if your motherboard supports your speekers it shoud run corectlly, but if not, you shoud get a special sound card with cd, which will allow you to use your speakers. if you already have that sound card and installed drivers you should go to your sound card control pannel and make changes there to use all your sound system speakers.
Dec 29, 2008 | Computers & Internet
Sound only in 1 Speaker Instead of Two
not sure if this will help, go to your control panel and then to your sound and audio devices, on the volume tab check to see if both speakers are set to high on the speaker volume option
hope it helps
Jun 13, 2008 | Philips Dynamic Edge 4.1 PSC604 Sound Card
Speakers
Test the speakers by changing source to the disc mode, and inserting a dvd into the HTS. If you get sound on all 5 speakers in DVD mode, then your speakers are still good. If you don't get sound on all 5 speakers, then press the "SURR" button to try the sound in stero, dolby, or other modes - one of these should give you sound on all 5 speakers. If you still don't get sound on all 5 speakers in dvd mode, then there is a problem with the speakers or speaker wires.
If you do get sound on all 5 speakers in disc (dvd) mode, but not when in TV mode, then take out the red and white AV cable, go buy a digital audio or SPDIF cable, and plug in the digital audio or SPDIF cable from the digital audio OUT of your TV or cable/satellite box to the "DIGITAL IN" of the HTS.
-Tha Mp3 Doctor
Feb 17, 2008 | Philips HTS3440/37 System
Philips MX3700D Digital Surround Sound Receiver System System Logo
450 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
