Question about Cosco Juvenile Scenera Convertible Car Seat - Daisy Daze
I need help putting my childs care seat back together
  • 25 Answers
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps. Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat. The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it doesn't twist, either. There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side. Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.) If you also took the **** buckle out, it goes back in from the top. Turn it so that you can slip the metal plate through the slot, slide it through, and then pull the plate flat underneath, so that it can't come back through. One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Posted on Feb 19, 2009
I have a quinny senzz stroller and the bracket and or brace that allows the seat to recline has come detached. I am trying to figure out how to put it back together. Any ideas?
I would do research about the stroller with carseat custom car seats and strollers are on recall and be very careful what you're putting your child in and look up research about the company if this keeps up I would recommend you buy a better stroller and carseat
Oct 09, 2016 | Quinny Baby Gear
Safety 1st model number 1c034 I took it apart to clean it and now cant put it back to together.... I have 2 extra medel pieces... HELP!!
Find a fitting station at www.nhtsa.gov. They will help you reassemble the seat. DO NOT GUESS!
-- Marc
Passionate Child Passenger Safety Instructor
Aug 13, 2014 | Baby Gear
I have a Edinburgh delux booster car seat. I needed to wash the cover and unbuckled everything and now I don't know how to put it all back together. Please help me I've tried googling the seat
Contact a certified Child Passenger Safety Technician (or equivalent if you are not in the USA). www.nhtsa.gov
It MUST be reassembled correctly. Do not guess!
Apr 11, 2013 | Baby Gear
I took apart the car seat for the eddie bauer adventurer travel system and trying to put it back together. Please help.
Contact a local Child Passenger Safety Technician (or equivalent if you are not in the USA) for help. www.nhtsa.gov
The seat MUST be rethreaded correctly for the safety of your child. Do not guess!
Apr 01, 2013 | Eddie Bauer Baby Gear
Cosco Alpha Omega Elite 3-in-1 Car Seat
DEAR SIR,
To start off, this seat can be purchased for around $100! For $100 you can get a seat that is 3-in-1 just like the name says. This means it can be used rear-facing, forward-facing and as a belt positioning booster seat. If your child weighs anywhere from 5-100lbs they can use it!
• This seat has comfortable fabric so your child sits comfortably during every car ride.
• It includes a push in harness adjustment lever.
• Has fold up armrests.
• LATCH compatible to ensure the safety of your child.
• And lastly, it has a harness and headrest that adjust together to never need rethreading.
This seat has all the features your little one needs to stay safe.
Find the best Cosco Car Seats at FindMyCarSeat.com.
THANK YOU...TAKE CARE
Oct 12, 2010 | Toys
We have purchased 2 Graco Nautilus 3 in 1 car seats and we have had them about 6 months. We are having a big problem with the buckle sticking. We push down as hard as possible and the buckle has a really...
I am having the same problem with my car seat. May be we need to contact Graco to see if they can correct this problem. There is no way of saving a child if there is an accident or fire. My fingers hurt from trying to unbuckle. This is insane. Graco needs to recall this seats!!!!!
Oct 01, 2010 | Graco Nautilus 3-in 1 Car Seat
Child car seat - unable to put it back together after washing
You need to pass the belt behind the sit.
Mar 21, 2009 | Baby Gear
Can't put back together
Do you have a company name for this product? Graco, Cosco? If you do I can look up an online manual for you as there is most likely a diagram to make my description easier for you to visualize. At any rate you need to insert 2 of the straps (the ones with the pieces to snap into the buckle at the **** ) through the back side (aline your child with the slots to ensure correct placement. You want the belt to come out just above the shoulder) DId you take this completely apart to wash? If so you will need to slip on the chest buckle pieces as well. Hope this helps. I can help better if you are able to get back with the company name so I can get the manual for you. :)
Aug 16, 2008 | Baby Gear
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Cosco Juvenile Scenera Convertible Car Seat - Daisy Daze Logo
360 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
