My new motorola sliver l7 wont format my 512mb micro sd card. It tells me that the format has failed, about 25 times. I reset the factory settings and it didnt help. I tried to format the card using a mac and a pc and the phone keeps telling me it is unformatted. The SD card works like a charm in my canon digital camera so the card is not at fault. Thanks for any help that can be given.
B
SOURCE: My mp3 player on the motorola L7
Some song formats aren't supported by some MP3 players. You can convert those songs that aren't compatible by using one of the loads of audio converters available online. Use a search engine to find the software that best fits your needs and you should be up and running in no time.
SOURCE: unlock sliver L7
HI dude,
to bypass the security, i hv got a trick.
When u r asked for security code,
press menu button(above the directional keys) for 3-4 seconds.
if u hv done properly the gap for 4 digits will be changed to 6 digits
slot. Now enter 000000 (six zero). now u will bypass the security
code. By same process u can change or reset security code from settings.
Looking for ur kind feedback. Dont forget to Rate my solution too.
Be sure to post a clarification request after ur problem is solved.
SAJAN([email protected]/[email protected])
SOURCE: motorola L7 bluetooth,micro sd problem
If bluetooth has failed to turn on,then it can be suffering from either the hardware or software problem.
you also said that mobile is also turning off, when you insert microsd card.
For that,
1. Try any other microsd card and see if the mobile works good.
If this works, then the fault is with the microsd card.
2. There are chances, that there may be virus in the microsd card that can cause this problem. Try to format it.
3. Also you can try your microsd card with other mobiles and see how it goes.
Last try is you can reset your phone and see, but have a back up of all the datas in your mobile before reset.
If none of the above works well, then you have give to the Motorola service center
or visit,
www.motorola.com/products.jsp to find the nearest service center.
Hope my info helps you,
Thanx for using fixya.
SOURCE: my slvr L7 doesn't recognize new 2 gb micro sd memory.
You can increase the memory upto 1GB not more than that.
