Whirlpool washer topload about 12 years old
  1. washer will not turn on until i unplug it then plug it back in.
  • 15,935 Answers
It appears your machine's timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Whirlpool thin twin #LT7000XUNO washer timer doesn't turn, have to do everything manually. Easy fix?
A) I've never worker on the dual stacked setups.
B) Standard topload is easy. Make sure you unplug it first, locating a replacement timer will be the hardest part. Most places around here are "wholesale" and only sell to techs. You used to could walk in with a maintenance uniform and buy the parts, for cash, then they started requiring company accounts. We still have at least one that sells retail parts. You may have to check the internet. You'll need the Manufacturer, Model, and , maybe the serial number.
Then the access to the backside of the timer usually involves removing a back panel or lifting the entire top of the assembly. With a dual I'd figure it to be a back panel.
C) Then you second hardest and most critical part is labeling your connections and making sure that you plug them into the exact same place on the new one that they now reside on the old one.
Apr 19, 2014 | Whirlpool LTE6234D Top Load Stacked...
How do we fix the washing machine when it says, system locked
unplug for a minute then plug in or turn circuit off for a minute and back on. It worked for me.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Howling or squealing noise when the machine is filling with water
there is a restriction in the valve assembly. it is servicable so remove it, open it up on both hot and cold and clean thoroughly. replace and test
Jul 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool ultimate care II topload washing machine
Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Jan 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Topload washer dripping
of course its proably just a water valve leaking
Jan 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
