Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire model FRS6LE4FW0 water dispenser does not work.
Have a Frigidaire model FRS6LE4FW0 side-by-side. Ice maker works fine but water dispenser does not. Actuator is O.K. I can hear the buzz of the water solenoid but no water dispensed. The frig is about two years old.
  • Anonymous Jan 02, 2009
    I have the same model and same problem with the water dispenser and also no water goes into the ice maker. HELP!!!! Thank you in advance
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
Frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Jul 24, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
518 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
